I installed Home Assistant OS 17.
I’m installing add-ons (MariaDB, Terminal & SSH) from the official add-on store.
When I make changes to the configuration and click Save, I get an error ‘Failed to save add-on configuration, Unknown error, see supervisor logs’.
I think this is a common issue affecting all add-ons in the system. It might be related to docker containers.
Please advise what I’m doing wrong?
(Additionally, I tried reinstalling Home Assistant OS and also tested version 15.2, but the problem persists.)
Please share the supervisor logs.
reboot and trying to configuring ‘Terminal & ssh’ add-on:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2026-02-04 14:42:55.785 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-02-04 14:42:55.787 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2026-02-04 14:43:59.827 WARNING (MainThread) [homeassistant.core] Something is blocking Home Assistant from wrapping up the start up phase. We're going to continue anyway. Please report the following info at https://github.com/home-assistant/core/issues: hassio, radio_browser, homeassistant, websocket_api, homeassistant.scene, wake_word, homeassistant_alerts, recorder, device_automation, assist_pipeline, camera, stream, input_text, google_translate.tts, met.weather, backup, panel_custom, hacs.switch, button, auth, file_upload, energy.sensor, onboarding, cloud.tts, repairs, binary_sensor, bluetooth, sun.sensor, input_datetime, google_translate, backup.event, mqtt, analytics, api, shopping_list.todo, sensor, webhook, mqtt.button, dhcp, cloud, file, script, todo, backup.sensor, network, stt, mqtt.binary_sensor, my, mqtt.switch, hassio.binary_sensor, input_select, diagnostics, system_health, input_number, ffmpeg, hacs, config, met, http, labs, tts, hardware, trace, hassio.sensor, logger, ssdp, zone, shopping_list, conversation, media_source, notify, web_rtc, lovelace, persistent_notification, usage_prediction, hassio.update, sun.binary_sensor, switch, hacs.update, tag, image_upload, mobile_app, blueprint, energy, scene, sun, update, event, history, hassio.switch, timer, default_config, mobile_app.notify, frontend, person, input_boolean, counter, weather, logbook, input_button, usb, automation, schedule, select, zeroconf, mqtt.select, mqtt.sensor, system_log, application_credentials, intent, go2rtc, search The system is waiting for tasks: {<Task pending name='Task-290' coro=<HacsBase.startup_tasks() running at /config/custom_components/hacs/base.py:666> wait_for=<Future pending cb=[Task.task_wakeup()]> cb=[set.remove()]>}
2026-02-04 14:44:30.169 ERROR (MainThread) [homeassistant.components.homeassistant_alerts.coordinator] Timeout fetching homeassistant_alerts data
2026-02-04 14:45:10.167 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/options/validate request
2026-02-04 14:45:10.167 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_ssh/options/validate -
