Hi everyone,
I wanted to share a Home Assistant add-on I built that lets you send and receive WhatsApp messages directly from your automations — no cloud service,
no subscription, runs entirely on your own hardware.
What is it?
WAHA (WhatsApp HTTP API) is a self-hosted REST API for WhatsApp. This add-on wraps WAHA as a native Home Assistant add-on so you can:
- Send WhatsApp messages from any automation
- Receive incoming WhatsApp messages as HA webhook triggers
- Control everything via REST API from rest_command
- Run it on a Raspberry Pi 4/5 or any x86 machine
No paid subscription. No external service. Everything stays on your network.
Installation
Go to Settings → Apps → Install App → Respositories(triple dot - top right) → Add
Add
https://github.com/sushiljain1989/hassio-addons -
Find WAHA WhatsApp in the store and click Install
Start the add-on(See Docs)
Send a WhatsApp message from an automation
Add to configuration.yaml:
rest_command:
send_whatsapp:
url: "http://localhost:3000/api/sendText"
method: POST
headers:
Content-Type: application/json
X-Api-Key: "your-api-key"
payload: '{"chatId": "{{ phone }}@c.us", "text": "{{ message }}", "session": "default"}'
Then use it in any automation:
- alias: "Notify on motion"
trigger:- platform: state
entity_id: binary_sensor.garden_motion
to: "on"
action: - service: rest_command.send_whatsapp
phone: "491234567890"
message: "Motion detected in the garden!"
- platform: state
Receive WhatsApp messages as HA triggers
Set the webhook URL in the add-on config:
WHATSAPP_HOOK_URL=http://homeassistant:8123/api/webhook/whatsapp_incoming
WHATSAPP_HOOK_EVENTS=message
Then create a webhook automation in HA and trigger it from any incoming WhatsApp message.
Supported hardware
│ Architecture │ Device │
│ aarch64 │ Raspberry Pi 4, Raspberry Pi 5 │
│ amd64 │ x86 PC, Intel NUC, VM │
Links
- Repository: GitHub - sushiljain1989/hassio-addons: Self-hosted WhatsApp HTTP API (WAHA) as a native Home Assistant add-on — send and receive WhatsApp messages via REST API from your automations, no cloud dependency required. · GitHub
- WAHA project: https://waha.devlike.pro
Important Notice
This add-on uses an unofficial WhatsApp API and violates WhatsApp's Terms of Service. Your account may be banned. It is intended for personal,
non-commercial use only. Please read the full disclaimer in the repository before installing.
Happy to answer questions. Feedback and suggestions welcome!
