I just uploaded the “Proxon” part of the dashboard to Github. (Dashboard_new.yaml)
Some automations are no more necessary.
and you need the integrations
bubble card
vertical stack-in card
button-card
card-mod
Theme bubble (not mandatory)
The topic about “Modbus schreiben”: I didn’t ask the support if there is a way to do that by myself. I was writing a message via the contact form and they called me back next morning and told me, that they have changed it remotely to “2”. So just give it a try.
no problem. just ask in case of questions.
I tried to have the information as compact as possible, since I wanted to use the same stack on my “home-page” as bubble-popup.
e.g. the temperatures. When I touch the temperature button, the temperature popup appears.
@Stroett - Hi, would you have any idea why my modbus connection using Waveshare Industrial USB to RS485 Converter is not working? I tried so many things I found but none are working.
Hey Rick99,
sorry for late response.
I just used the USB Adapter for troubleshooting purpose (in general Im using the Ethernet version).
So far I remembered only connecting the wires to these 3 pins, was fine.
Than it worked for me in the modus testing tool as also direct in home assistant.
Hi Jan,
you are right. Missed that in the configuration.yaml.
Should be now added on GitHub.
But you are not completely right.
The status is not, if the heating is allowed to turn on, but if its currently heating. That’s why the following templates should be correct.
- binary_sensor:
- name: Proxon Heizelement Status Wohnzimmer
state: "{% if states('sensor.proxon_heizelement_status') | int | bitwise_and(1) %}on{% else %}off{% endif %}"
unique_id: proxon_heizelement_status_Wohnzimmer
- name: Proxon Heizelement Status Flur
state: "{% if states('sensor.proxon_heizelement_status') | int | bitwise_and(2) %}on{% else %}off{% endif %}"
unique_id: proxon_heizelement_status_Flur
- name: Proxon Heizelement Status Buero
state: "{% if states('sensor.proxon_heizelement_status') | int | bitwise_and(4) %}on{% else %}off{% endif %}"
unique_id: proxon_heizelement_status_Buero
- name: Proxon Heizelement Status Schlafzimmer
state: "{% if states('sensor.proxon_heizelement_status') | int | bitwise_and(8) %}on{% else %}off{% endif %}"
unique_id: proxon_heizelement_status_Schlafzimmer
- name: Proxon Heizelement Status Eline
state: "{% if states('sensor.proxon_heizelement_status') | int | bitwise_and(16) %}on{% else %}off{% endif %}"
unique_id: proxon_heizelement_status_Eline
- name: Proxon Heizelement Status Lean
state: "{% if states('sensor.proxon_heizelement_status') | int | bitwise_and(32) %}on{% else %}off{% endif %}"
unique_id: proxon_heizelement_status_Lean
- name: Proxon Heizelement Status Hobbyraum
state: "{% if states('sensor.proxon_heizelement_status') | int | bitwise_and(64) %}on{% else %}off{% endif %}"
unique_id: proxon_heizelement_status_hobbyraum
for that you need in addition the following sensor via modes
Hi and thanks for sharing,
the address 574 is in my Case (Proxon FWT from Year 2021) 4x0574 Freitag #2 Zeit Minuten An ZL069:Zeitprogramm Luftmenge, so its part of the time-program…
Can you share some more informaition about the modbus address? Is it this one? Heizmodul 1 Relaistest T12:Test Binär “Bit9:R10
Bit8:R9
Bit7:R8
Bit6:R7
Bit5:R6
Bit4:R5
Bit3:R4
Bit2:R3
Bit1:R2
Bit0:R1”
great job all of you did here to connect the FWT to HomeAssistant. After reading very much, I thoght I give it a try. I have a FWT 2-R which seems not to be connected to the T300.
indeed I was wondering about this as well. For me it’s not clear, how to differentiate about the different tabs in the Excel-Sheet.
On Tab “Holding Register” there is at the address 4x0574 the value of “Freitag #2 …:” (like Peter said). But on the tab “Input Register” there is at the address 3x0574 the value of “Heizmodul 1 Relais Status”.
(at least I have no idea what’s the difference between these two excel tabs - sorry).
I have an additional question regarding the switch proxon_heizelemente_global. What does this switch do? Does this switch activate all heating elements?
Nothing happens in the Proxon-App
Or do I have the problem with R/W (modbus write modus)?
Thanks in advance.
this switch allows the heating elements to heat or not, depending on their own status.
Means … if the switch “proxon_heizelemente_global” is off, no all heating elements are off.
If the global switch is on, the elements are on or off depending to their own status.
Does it help?
and about the other question:
as I mentioned in the response message to Peter…
These are different register types. It’s explained on Wiki. I am also no expert in modbus
AHHHH now after reading the message from charty …
He is right. Yup were looking in the wrong register. You hav to differentiate between holding and input register.
Don’t ask about more details But this is also important the the config file. There you tell the input type … see below
