Add smart control to Arkoslight LED lamp
Good Afternoon,
I am sorry if this message is in the wrong section but I have been looking for days for a solution to my problem but without success…
I have an Arkoslight Rec LED lamp with an integrated controller.
In order to dim it the lamp is connected with 5 wires:
  • L, from electrical panel
  • N, from electrical panel
  • Ground, from electrical panel
  • Input “1”, connected to NO buttons/switches
  • Input “2”, connected with a “bridge” to N input (this has been suggested by the producer itself)
    In order to turn it on/off and dim it, I have used some NO buttons/switches connected in parallel. One simple click would turn on/off the lamp, if I keep them pressed the light dims up or down.
I would like to make this lamp smart and I have tried different Bticino objects:
  • K4411C Connected dimmer/switch
  • K4003C Connected two-way switch
  • 3584C Connected lighting micromodule
    None of them seemed to work correctly, since I was not able to dim gradually the light and I had to press quickly two times to shut it off and it did not always work.
Is there a Zigbee or another smart device, like a relay, that I can connect in parallel to the buttons or attached to one of them that can allow me to use the lamp remotely and also dim it?
Thank you in advance for your help!
