All, just installed my first Voice PE. I know that Music Assistant will add the magic here to also make it a full blown mediaplayer (with external speakers). However, as long as Music Assistant does not support bandcamp I’m not switching.
So, just wondering, is there a way to add squeezelite functionality to the Voice PE (via ESPHome)? If so, how?
Apparently, the Assistant on WearOS picks the first Assist pipeline in the Assistants settings. That was an old one I didn’t use anymore and which wasn’t properly configured. Everything worked again as soon as I configured it properly.
I thought it would pick the same pipeline as I have chosen in Assist on the Android app (or the preferred one, which it also doesn’t), but apparently it doesn’t.
However, I could not find any means to select a different pipeline for Assist on WearOS. Anyone knows how to do that?
Just wondering if you were able to figure this out?
I’m currently using Music Assistant with the Home Assistant provider, but it would be great if I could switch to Squeezelite to sync playback to my other devices.
