Now that we can define blueprint template sensors , I’m looking for a way to manually trigger a specific template sensor to update.
The only way I’ve come up with is to define a custom event and pass in some kind of event data from an input:
blueprint:
input:
name:
- trigger: event
event_type: MY_UPDATE_TEMPLATE
event_data:
- trigger: event
event_type: event_template_reloaded
I think it would be nicer if trigger based template sensors supported homeassistant.update_entity
. This way I don’t need to implement a custom event.
Since some trigger template sensors require data, maybe it’s better to have the trigger template sensor opt in to supporting this functionality?
- trigger:
- trigger: homeassistant # New part
event: update_entity
- trigger: event
See homeassistant.update_entity called on a trigger-based template sensor results in a "not implemented" error · Issue #140730 · home-assistant/core · GitHub for some more background.
