One important part, which is only mentioned once on the CHANGELOG.md but not in the setup for the connection at qingping is the following:
Do NOT add :
when you add your mac address. Both on the quinping website as well as in home assistant when you manually add the integration (automatic detection did not work for me)
Please take a look at the /up messages and compare the timestamps with the current unix time.
It seems the problem to me that after restarting the device unix timestamp starts at 0. And the plugin likes to have correct timestamps (dont knoe why the device time should care for this integration)
How do everyone here deal with that?
Were you able to fix this, I followed the instructions, but all my values are also unavailable. I also couldn’t get it discovered, once I added it manually with the MAC address it showed no values.
Did you manage to solve the problem? I have the same one.
