Add support for Yeelight Strip 6
Based on the Yeelight documentation:
strip6 is not yet supported
Brand: Yeelight
Model: yeelink.light.strip6
Home Assistant discovery also shows this to only be compatible via Homekit only which is sad.
What is sad about it?
I will be closing this feature request because I managed to make Yeelight Strip 6 work with Home Assistant.
Hello
Can you explain me how, please ?
Make sure you are using the latest HassOS and Supervisor.
My Yeelight Strip 6 was automatically detected via the UI and not via YAML.
Hello
I’ve the latest version of both of them.
the strip wan’t automatically detecte, si I’ve added manually the @ip but no equipment was created :frowning:
