Add unit of measurement after trigger offset
When creating an automation, there is a handy offset to add a delay after the trigger, but it is unclear what the unit is. For a half an hour, do I put 30 or .5?
Chris
If you don’t identify the for: component, I believe it is seconds.
All other time measurements require the associated key.
Please read the docs for more detail…
I went to the docs and they give an example in yaml “-00:30:00”.
The UI prompt where I put 30 was, like you said, in seconds.
I guess what I’m getting at is that it would be helpful to add the characters “[sec]” so that it is clear and intuitive, or better yet, force you to fill in the time in that format HH:MM:SS, which is why tried communicating this in the feature request section (Although I am on my phone and apologize if this is the wrong place to make the suggestion)
