Add Xiaomi Aqara hub
I can’t add my Aqara hub from integration in HA. It says “failed to discover a Xiaomi gateway , try using the ip of the device running HomeAssistant as interface” I tried the ip from HA but same fail. Tried also the ip of the gateway, still same fail. Can see on google lots of people have same issue? But no solution so far ?
Same issue, I was wondering if anyone got a solution for this issue.
