Hi I have recently installed Home Assistant Supervised on a Raspberry Pi with Debian 10. So far so good. I have added the Hive Custom Component in HACS but when I go to add the integration: Configurations - Integrations - I can’t add it. Any idea what I can do I have checked that the Hive directory is in the Custom Compenents.
Found the answer
Remove the add on from HACS, remove the entry in config.yaml, restart. Then re add Hive 2020.1_b25 in HACS, restart, when back force refresh your browser and add Hive via the front end not config.yaml. Check the entities as names may have changed, eg gained a 1 or 2 on the end or similar, so delete the old ones and rename the new ones to match the old ones. Everything should then be back to where you started with no more input.
