Adding a ReSpeaker microphone
Hi Hassio community.
This is my first post.
I come from the world of Mozilla-IoT and Mycroft “AI”.
I have decided to give Hassio a try since it supports many more devices and this seems like a much more active community.
Sorry if I’m posting this in the wrong category.
I want to add a Seeedstudio ReSpeaker 4 mic array to Hassio:
h**ps://wiki.seeedstudio.com/ReSpeaker_4_Mic_Array_for_Raspberry_Pi/
This mic is quite pricey, but as most open source hardware, it makes it’s way to asia and the price drops significantly:
Actual question starts here.
Installing this mic is quite easy on any version of Raspbian, but I have come to understand that Hassio is a completely different animal.
Logging in as root is pretty straight forward following this guide:
h**ps://developers.home-assistant.io/docs/operating-system/debugging/#ssh-access-to-the-host
But.
There is no package manager, git or even a compiler on the system (that I can find).
I’m guessing I would have to compile this driver on another system and import the binary into Hassio and have it load on startup?
I’m a “noob” and have no idea how to do that.
I believe I have done my due diligence and googled around for an answer, but I have not found a good one.
What I’m trying to accomplish is to get “Hey Ada” working, before I buy a subscription to “Home assistant cloud”.
Please advice.
Simon
Mycroft works with home assistant too, not just Mozilla iot. Cheers!
Mycroft is a false positive nightmare. That’s why I want to get away from it.
I usually have a Twitch stream going in the background.
I would get 10-30 false positives for “Hey Mycroft” every day.
And how does your reply help me install the drivers for the ReSpeaker?
Stay Safe
Simon
Likely a configuration issue, I have been using Mycroft for 3+ years and don’t remember my last false positive, It does have issues with my wife though due to most of the training being male biased. Well if you are using re-speaker on Hassio unfortunately I am of no help to you. Hope it works out for you, definitely interested in how you make out. Take care!
@motionthings - I’m in the same boat. I just bought a quite pricey respeaker 4 mic array as I think they said its plug and play with Win, OSX and Linux so I plugged it into my NAS, passed it through to the hass.io VM, activated almond and ada and the ada logs told me its apparently missing drivers :-/
I can’t find any more info either. Have you figured out something in the meantime or found more information?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
ALSA lib confmisc.c:767:(parse_card) cannot find card '0'
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM sysdefault
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_hw.c:1822:(_snd_pcm_hw_open) Invalid value for card
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib conf.c:5014:(snd_config_expand) Unknown parameters {AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2  CARD 0}
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2  CARD 0}
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM dmix
