I’m struggling with configuration.yaml
, I can’t add an entity that will be accepted by the battery storage in energy dashboard.
I have a small off grid setup. It’s a combo inverter+charger with AC fallback unit (so when batteries run out of juice it switches to AC), so there is only 1 battery connection, no in and out and the energy dashboard requires both; will it work?
I made myself a MQTT power/energy meters, the meter sends data from the sensor via JSON to NodeRed that then sends the data into InfluxDB.
JSON Structure:
{"B-V":25.76836,"B-I":-7.645916,"B-W":-196.6761,"B-E":-0.354719,"B-S":93,"S-V":28,"S-I":7.750885,"S-W":217.6576,"S-E":0.390405,"A1-V":0,"A1-I":0,"A1-W":0,"A1-E":0,"A1-F":0,"A1-P":0,"A2-V":225.7025,"A2-I":0,"A2-W":0,"A2-E":0.224,"A2-F":49.98183,"A2-P":0,"RSSI":-70.87584}
Where B- is battery, S- are solar panels, A1- is AC in and A2 is AC out. All energy statistics reset at 00:00.
My configuration.yaml
, what should I change/add?
# Sensors
- platform: mqtt
state_topic: "power/solar/den"
unit_of_measurement: "dBm"
state_class: "measurement"
unique_id: "SolarRSSI"
device_class: "signal_strength"
value_template: "{{ value_json.RSSI }}"
- platform: mqtt
name: "Solar AC in energy"
unit_of_measurement: "kWh"
unique_id: "SolarACInEnergy"
device_class: "energy"
value_template: "{{ value_json['A1-E'] }}"
- platform: mqtt
name: "Solar battery energy"
unique_id: "SolarBatteryEnergy"
value_template: "{{ value_json['B-E'] }}"
- platform: mqtt
name: "Solar AC out energy"
unique_id: "SolarACOutEnergy"
value_template: "{{ value_json['A2-E'] }}"
- platform: mqtt
name: "Solar AC in voltage"
unit_of_measurement: "V"
unique_id: "SolarACInVoltage"
device_class: "voltage"
value_template: "{{ value_json['A1-V'] }}"
- platform: mqtt
name: "Solar Panel Energy"
unique_id: "SolarPanelEnergy"
value_template: "{{ value_json['S-E'] }}"
utility_meter:
daily_energy_battery:
source: sensor.solar_battery_energy
name: Daily Energy Batetry
cycle: daily
daily_energy_solar:
source: sensor.solar_panel_energy
name: Daily Energy Solar
cycle: daily
daily_energy_in:
source: sensor.solar_ac_in_energy
name: Daily Energy In
cycle: daily
monthly_energy_in:
name: Monthly Energy In
cycle: monthly
daily_energy_out:
source: sensor.solar_ac_out_energy
name: Daily Energy out
cycle: daily
monthly_energy_out:
name: Monthly Energy out
cycle: monthly
template:
- sensor:
- name: "solarenergybalance"
state: "{{ states('sensor.solar_ac_out_energy')|float - states('sensor.solar_ac_in_energy')|float}}"
unit_of_measurement: 'kWh'
unique_id: "SolarEnergyBalance"
