Adding Custom Repository For zigbee2mqtt - Not Compliant?
Hello.
Setting up new Home Assistant Blue, and migrating each component from my old docker install on synology NAS. Now to deal with Zigbee.
When I follow instructions to add zigbee2mqtt it simply does not work.
HACS → Integrations - Custom Repositories →
Add the source - https://github.com/zigbee2mqtt/hassio-zigbee2mqtt
Set type as “Integration”
Then I get this error:
Repostitory structure for v1.21.1-1 is not compliant
I’m guessing this is a problem with the repository and nothing at my end?
Thanks in advance
Colin.
it is not a custom component, so not for HACS.
Supervisor → add-on store → 3 dots in the corner → repositories
Thank you!!! Simple as that - you’re a star.
Still getting my way round Supervisor / HACS vs dockers on my old system. Assume repositories were in HACS - didn’t realise also in Add-On Store.
Thanks again. +1 on the learning curve.
