Can I include the result of a formula in the contents of a message I am sending to TTS from an automation?
something like this: xxx days left until vacation
where xxx is the formula: july 1st, 2021 - today
Thanks,
Rich F
Thanks,
Rich F
Yes.
Thatās not a āformulaā. The example you posted shows a string. Do you want to pass the string as a variable (to a script) or does it represent the state
value of some other entity you have?
How you doing Taras?
July 1, 2021 is just arbitrary date I picked. It is stored nowhere.
I entered the following in Developer Tools -> Template
{{ (as_timestamp("2021-07-01 00:00:00") - as_timestamp(now())) / 86400 }}
and got result of 110.33374605195665 which is pretty close but is not an integer value.
What is the syntax to precede the message text " days left until vacation" with the 110.33374605195665 after formatting it to look like as an integer? Is that possible?
In VBscript I think you would use Cstr(Cint()) & ā days left until vacationā
Thanks,
Rich F
Try this (slightly extended)
{% set days = ((as_timestamp("2021-03-13 21:00:00") - as_timestamp(now())) / 86400) | int %}
{{ days }} {{'day' if days == 1 else 'days' }} left until vacation.
Taras,
That worked in under Developer Tools OK. But when I entered it into automations.yaml I get a ābad indentation errorā for the attribute "message: " The script is to run weekly up until 7/1/2021.
- id: test01
alias: test01
description: 'test01'
- platform: time
at: '16:35:00'
condition:
- condition: template
value_template: '{{ as_timestamp(now()) <= as_timestamp("2021-07-01 00:00:00") }}''
- condition: and
conditions:
- condition: time
weekday:
- fri
- service: notify.alexa_media
- media_player.computer_room_dot
type: tts
message: {% set days = ((as_timestamp("2021-07-01 00:00:00") - as_timestamp(now())) / 86400) | int %} {{ days }} {{'day' if days == 1 else 'days' }} left until vacation.
mode: single
Rich F
type: tts
message: >
mode: single
And change your conditions, they are AND by default.
condition:
- condition: time
weekday:
- fri
Edit: By the way, Iām not Taras
Sorry about that.
FWIW, hereās an alternative way of calculating days using datetime objects.
message: >
{% set d = (now().replace(month=7, day=1, hour=0, minute=0, second=0) - now()).days %}
{{d}} day{{'' if d == 1 else 's'}} until vacation.
Taras,
I got it work using your code snippet. I just realized the GUI is just too finicky in creating automations and did it using File Editor.
Thanks,
Rich F
Glad to hear it worked.
As a separate issue, I believe you have misunderstood the purpose of the Solution tag. You marked your last post as the Solution but it contains no explanation or example.
The whole point of a Solution is to direct users to the one post in the entire thread that describes the cause of the problem and/or offers a way to resolve it. Your last post contains neither yet itās the one that other users will be directed to.
