Hefford27
(Graham Hefford)
October 23, 2017, 9:39pm
1
Hi
I am sure this has come up before, but I cant seem to find anything to help me.
What i am looking to do is the following
Any anyone help or point me in the right direction
benji87
(Benjamin Gordon)
October 24, 2017, 8:01am
2
If you have them as part of an automation then you can simply do the following to get the timestamp of when they were last triggered:
{{ states.automation.turn_on_dining_room_lights.attributes.last_triggered }}
lolouk44
(lolouk44)
October 24, 2017, 1:51pm
3
As per @benji87 , however if you don’t use it as part of an automation, then you’d need to create a small script that extracts the info from your DB.
if you want/need I can share my script to retrieve such info. Let me know
Hefford27
(Graham Hefford)
October 24, 2017, 3:44pm
4
Hi Mate that would be great if you could share help me learn the more advanced stuff
Thanks appreciate it…
lolouk44
(lolouk44)
October 24, 2017, 8:23pm
5
here is the script:
#!/usr/bin/python
# -*- coding: utf-8 -*-
import MySQLdb as mdb
from dateutil import tz
from_zone = tz.gettz('UTC')
to_zone = tz.gettz('Europe/London')
try:
con = mdb.connect(sqlhost, sqlusername, sqlpassword, sqltable)
cur = con.cursor()
cur.execute("SELECT `last_updated` FROM `states` WHERE `entity_id` = 'sensor.xiaomi_status' and `state` = 'Cleaning' order by `state_id` DESC limit 1")
rows = cur.fetchone()
MyLastSeen = rows[0]
con.close()
except:
print "Unable to connect to HASS SQL Table (%s)" % datetime.datetime.now().strftime("%d/%m/%y %H:%M")
#convert UTC to British Time
MyLastSeen = MyLastSeen.replace(tzinfo=from_zone)
MyLastSeen = MyLastSeen.astimezone(to_zone)
print "%s" % MyLastSeen.strftime("%d/%m/%y %H:%M")
Then create a sensor:
- platform: command_line
command: "/home/USER/.homeassistant/shell_scripts/xiaomi_last_clean.py"
