I’m having trouble in where to start with adding 3 PWM fans on a single Tasmota to my HA configuration. In Tasmota everything is working fine but I don’t know which configuration lines I have to add to control them from HA. The command to control fanspeed is the channel command.
fan_controller/stat/RESULT = {"Time":"2020-02-19T12:31:31","Uptime":"0T00:01:25","UptimeSec":85,"Heap":26,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":99,"MqttCount":1,"POWER1":"ON","Channel1":13,"POWER2":"ON","Channel2":95,"POWER3":"OFF","Channel3":99,"Color":"33,242,252","Wifi":{"AP":1,"SSId":"-","BSSId":"-","Channel":10,"RSSI":100,"Signal":-39,"LinkCount":1,"Downtime":"0T00:00:06"}}
