I added my SolarEdge Inverter using the Configuration - Integrations - Add Integration. This part is working.
But I want to add a value template to change from Watt hours to kilo Watt hours as in the documentation, but where do I put the code? Tried adding to Configuration.yaml but I get an Invalid configuration. I did not find any other place to put it. Can it be added to the entities card for each sensor?, Thanks
The file editor shows a check mark and no errors.
If I use visual code it has me remove the semi-colons and say invalid type for the value_template.
If I run the configuration checker under the server control it goes into a continuous circle and does not return.
Can I add two sensor groups? Also the other platforms have a dash before them, should this be removed?
Suggestions?
Thanks for the help.
Thanks for the help Chris,
That was just one of the problems:
The template had the same name.
The quotes somehow got changed to the curved quotes instead of straight quotes.
I didn’t use the new name on the card, I was using sensor.solar_edge_inverter_current_power instead of sensor.solaredge_inverter_current_power_template.
At one point I had changed solaredge_inverter_current_power_kwh to solaredge_inverter_current_power_kWh, It didn’t like the capital letter.
I ended up using the customization off of the configuration page to set the units, device type and friendly name. Then I picked the new state for the entity on the card.
Chuck
