Hi!
So just got the Mi Smart Sensor Set and having troubles adding the control hub to HA. I did find the key “everyone” seems to struggle to get without too much trouble but now when I try to add the Xioami Gateway through Integration it is only asking for IP & MAC address (see screenshot) .
It also doesn’t find it automatically.
I’ve read the https://www.home-assistant.io/integrations/xiaomi_aqara probably more than I dare to admit.
What am I missing?
Thank you.
I also have a Gateway setup, and i only need to press submit and everything got done automatically. You could try to note down all the requested values and try again. Else another work around should be getting everything noted inside your config file. My vacuum cant get added through the integrations, but works fine through my configuration file
Just a side note. I’ve been noticing that if you add the gateway trough europe, its giving a lot of problems. I have added it through mainland china. This is one of the first prompts you get when setting up the Xiaomi home app on your telephone.
Thanks a lot for the prompt answer. So actually you helped me to dig further into things I read already and it seems that model I am using ( lumi.gateway.mieu01) doesn’t work well with HA. There is a bug being processed at the moment and it seems things are on the way.
I just need to wait a little.
Thank you.
