Adding ZHA Map to Lovelace Card
There is a way to add the ZHA map to a lovelace card instead of go to settings - integration ecc?
Thanks a lot
Stefano
There is still the custom component and lovelace card, so those might still work for you, but I can’t say whether those continue to receive any updates (or if they even work with the integration built in now).
As an alternative, maybe you might like Zigzag. It doesn’t seem very configurable to me, but it does seem to work properly with current ZHA.
I’ve just installed Zigzag and is, in my opinion, much better than the native ZHA visualisation. I like the way you can move nodes and they stay where the are put.
Thanks for the heads up
If you want to use the original visualisation, you coud use panel redirect:
You can find the path in the addressbar in your browser
- name: panel-redirect
  url_path: redirect-zha
  sidebar_title: ZHA Visualisation
  sidebar_icon: mdi:zigbee
  module_url: /local/panel-redirect.js
  config:
    target: /config/zha/visualization?config_entry=f2a9aaaa8ca942d0afff21b51c8c58ef
Thanks a lot for everyone :smiley:
I will check Zigzag and the redirect
