Hello everybody!
I am currently renovating my newly bought house.
Now I have a raspberry pi 4 with a zigbee stick.
I have installed Zigbee2mqtt Hass.io Add-on and added the following to the configuration:
“zigbee_shepherd_devices”: true
Then I put the following in the configuration of the file devices.js :
zigbeeModel: ['NUET56-DL27LX1.1'],
model: 'LXZB-12A',
vendor: 'Zemismart',
description: 'RGB LED Downlight',
supports: 'RGB, Dimming',
extend: gledopto.light_onoff_brightness_colortemp_colorxy
After this I tried to connect the lamp with home assistant but unfortunately it says the following:
`zigbee2mqtt:warn 9/18/2019, 9:20:46 PM Message without device!
I flashed the stick again and then tried to connect the lamp and I get the following message:
`zigbee2mqtt:warn 9/18/2019, 9:30:33 PM Message without device!
After this I emptied the database.db and flashed the stick again and then I get no message during the first connection.
After this I pressed the connect button again and I get the following message:
zigbee2mqtt:info 9/18/2019, 9:36:10 PM Device incoming...
zigbee2mqtt:info 9/18/2019, 9:36:10 PM MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"device incoming"}'
zigbee2mqtt:info 9/18/2019, 9:36:55 PM Device incoming...
zigbee2mqtt:info 9/18/2019, 9:36:55 PM MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"device incoming"}'
That’s all.
I don’t know what else I could do. I also tried to set zigbee shepherd to false, but then it says it’s an unknown device.
Has anyone had experience with this or the same experience that could help me with this?
