03397
November 6, 2020, 6:20pm
1
Guys, I have the following script.
I want to add this condition
{{ ‘RINCON’ in state_attr(‘media_player.sonos_one’,‘media_content_id’) }}
Only when this is TRUE the script should be executed. How can I add this?
sonos_say:
alias: Sonos TTS script
sequence:
- choose:
- conditions: "{{ states(sonos_entity) == 'playing' }}"
sequence:
- data_template:
entity_id: '{{ sonos_entity }}'
service: sonos.snapshot
entity_id: input_boolean.sonos_snapshot
- data_template:
volume_level: '{{ volume }}'
service: media_player.volume_set
- data_template:
message: '{{ message }}'
service: tts.google_translate_say
- delay: '{{ delay|default(''00:00:00'') }}'
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
- data_template:
service: sonos.restore
- service: input_boolean.turn_off
mode: queued
max: 10
123
(Taras)
November 6, 2020, 6:25pm
2
What not add that condition to whatever calls the script?
In other words, don’t even call the script if it’s asked to do something it doesn’t do.
If that’s impractical, simply add the condition as the first action in the sequence.
sonos_say:
sequence:
- conditions: "{{ 'RINCON' in state_attr('media_player.sonos_one', 'media_content_id') }}"
- choose:
... etc ...
03397
November 6, 2020, 6:55pm
3
It is impractical since the script is called inside over 20 automations.
Thanks I will try your suggestion.
03397
November 6, 2020, 7:06pm
4
After adding this as suggested I am getting an error after “Check Configuration”
Invalid config for [script]: [conditions] is an invalid option for [script]. Check: script->script->sonos_say->sequence->0->conditions. (See /home/homeassistant/.homeassistant/configuration.yaml, line 104).
tom_l
November 6, 2020, 7:27pm
5
I don’t think home assistant will accept a condition as the first action of a script or automation. I’ve seen this a few times on the forum.
As a test try:
sonos_say:
sequence:
- delay:
seconds: 1
- choose:
... etc ...
(Taras)
November 6, 2020, 7:29pm
6
Tricky! I didn’t know it was averse to delay
condition
as the first action.
EDIT
brain fart …
tom_l
November 6, 2020, 7:30pm
7
It’s not, it’s averse to condition
as the first action. The delay
is the workaround.
petro
(Petro)
November 6, 2020, 7:50pm
8
@123 @tom_l you can have a condition as the first action in a script. I do it all the time. The problem is a typo
- condition: "{{ 'RINCON' in state_attr('media_player.sonos_one', 'media_content_id') }}"`
or simply
- "{{ 'RINCON' in state_attr('media_player.sonos_one', 'media_content_id') }}"`
EDIT: It seems like the UI does not like this configuration method, so if you’re using the UI you have to use the old notation
- condition: template
value_template: "{{ 'RINCON' in state_attr('media_player.sonos_one', 'media_content_id') }}"
Otherwise, if you’re not… you can use the shorthand versions.
November 6, 2020, 8:25pm
9
Thanks guys.
Working like a charm
