Hi all,
I have Hass on docker.
All Addon such ass Cloudflare, Zigbee2MQTT, etc, in the log tab, it only shows “No errors have been reported” even I cannot start the add on successfully.
Could you advice how to make it show details info?
I have the same issue, and haven’t been able to figure it out. The symptom is more clearly described as “logs don’t show up in the live view until a long time has passed, but if I download the logs, I can view them in an external viewer”.
Whenever I load the Log tab, it always falsely shows “No errors have been reported” (not every “log” is an error, but uhh… thanks). I then download the log, actually view all the info about the add-on’s operation, go about debugging it, check back on the tab some minutes later, and… the logs are all being shown (as in the last screenshot). It just doesn’t show them when initially loaded.
Can’t seem to find any info about this, but the most appropriate thing to do is to group it together with an unanswered post from someone else with exactly the same behavior.
Especially frustrating as I’m trying to develop an add-on (but this has been an issue on my server for months prior).
Someone has found a solution?, I have exactly the same problem.
