I have been busy getting my alarm system setup and so far pretty happy with it, going to mount a tablet at the front door as soon as the wall mount is delivered. I am using the MQTT Alarm App for that. As I put this together I realized there is no good way to know other than to check Home Assistant if the Alarm is set which results with the alarm going off when letting out the dog. Since the front door is pretty visible from most areas of the first floor I thought of mounting an addressable LED strip in the top moulding. The idea then would be to turn one LED on as Red when the alarm is set. I could also do a visual countdown over 30 seconds for the exit delay (all on to off). When the alarm goes off I could flash the LEDS Red and Blue. Other ideas include turning one led on (Blue) if mail was delivered, another could be to turn on less if motion was detected on one of the security cameras (turn on several but slowly turn them off as time passes).
So I have been searching the internet for ideas or example on how to put this together. I would prefer to use ESPHOME as I am getting comfortable with it. So could use the FASTLED platform. One of the key considerations is to control the light from Home Assistant. Wondering what the best way to accomplish this. I had considering creating effects but not sure that would work for situations where I would want to show multiple notifications (alarm on and motion detected).
Examples are always welcome if someone can point me in the right direction.
yvosound
(Yvosound)
February 27, 2021, 11:23am
2
VikingBlod:
FASTLED
did you found a solution?
I never got a response on this thread but did put something together which I included here. Some of my ideas didn’t make it (like the visual countdown) But most of the others did. This configuration is far from perfect but it works.
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_pswd
power_save_mode: none
fast_connect: true
manual_ip:
static_ip: !secret frontdoorledsrip_ip
gateway: !secret gateway
subnet: !secret subnet
ap:
ssid: " Front Door Hotspot"
password: !secret esphome_pswd
captive_portal:
logger:
level: DEBUG
esp8266_store_log_strings_in_flash: False
api:
ota:
web_server:
port: 80
globals:
- id: trigger_status
type: int
restore_value: no
initial_value: '0'
light:
- platform: fastled_clockless
chipset: WS2812B
pin: D4
num_leds: 300
rgb_order: GRB
name: "Front Door Light Strip"
internal: true
- platform: partition
restore_mode: ALWAYS_OFF
segments:
- id: fastled_clockless_led
to: 94
segments:
to: 92
segments:
to: 90
effects:
- addressable_lambda:
update_interval: 20ms
lambda: |-
static int x = 0;
if (initial_run) {
x = 0;
if (x < it.size()) {
it[x] = ESPColor::BLACK;
x += 1;
lambda: |-
static int x = 0;
if (initial_run) {
x = it.size();
it.all() = ESPColor::BLACK;
if (x > 0) {
x -= 1;
it[x] = current_color;
segments:
to: 90
effects:
name: "Alarm Event Triggered"
update_interval: 2ms
lambda:
static int step = 0;
static int direction = 1;
if(initial_run){
step = 0;
it[step] = ESPColor(255,0,0);
if(step >0 && step < it.size()){
it[step + (direction * -1)] = ESPColor::BLACK;
step = step + direction;
if(step >= it.size() || step < 0){
direction = direction * -1;
step = step + (direction * 2);
segments:
to: 69
effects:
update_interval: 3600ms
lambda: |-
int range_from;
int range_to;
int red_color;
int green_color;
int blue_color;
if (id(outside_temp).state >= 0) {
range_from = 40 - id(outside_temp).state;
range_to = 40;
} else {
range_to = 41 + (id(outside_temp).state * -1);
range_from = 41;
for (int i = range_from; i < range_to; i+=1) {
red_color = (39 - i) * (255 / 40);
green_color = 0;
blue_color = (255 / 40) * i + 1;
} else {
red_color = 0;
green_color = (i - 40) * (255 / 30);
blue_color = 255 - ((255 / 30) * (i - 40));
// ESP_LOGD("custom", "Value of I: %i. Colour Red %i, Green %i, Blue %i", i, red_color, green_color, blue_color);
it[i] = light::ESPColor(red_color, green_color, blue_color);
it[40] = light::ESPColor(255, 190, 0);
binary_sensor:
- platform: homeassistant
entity_id: group.outside_motion
internal: True
on_state:
then:
- if:
condition:
lambda: 'return id(trigger_status) == 0;'
then:
- script.execute: motion_status_script
entity_id: group.monitored_sensors
internal: True
on_state:
then:
- script.execute: sensor_open_check
- platform: gpio
pin:
number: 14
# inverted: True
mode: INPUT_PULLUP
filters:
- delayed_on: 1000ms
device_class: door
name: "Outside Temperature"
entity_id: sensor.rear_porch_temperature_measurement
internal: True
on_value:
then:
- if:
condition:
and:
- lambda: 'return id(trigger_status) == 0;'
- lambda: 'return id(outside_temp).state <= 40;'
- lambda: 'return id(outside_temp).state >= -30;'
then:
- light.turn_on:
effect: "Temperature Effect"
brightness: 50%
text_sensor:
name: "Alarm Panel Status"
entity_id: alarm_control_panel.ha_alarm
internal: True
on_value:
then:
- script.execute: alarm_status_script
script:
- id: motion_status_script
then:
- if:
condition:
lambda: 'return id(outside_motion).state;'
then:
- light.turn_on:
effect: "Wipe In"
brightness: 25%
red: 43%
green: 100%
blue: 85%
else:
- light.turn_on:
effect: "Wipe Out"
brightness: 25%
- id: alarm_status_script
then:
- if:
condition:
lambda: 'return id(alarm_panel_status).state == "armed_home";'
then:
- light.turn_on:
brightness: 50%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: 'return id(alarm_panel_status).state == "armed_away";'
then:
- light.turn_on:
brightness: 50%
red: 100%
green: 0%
blue: 0%
- if:
condition:
lambda: 'return id(alarm_panel_status).state == "pending";'
then:
- light.turn_on:
brightness: 50%
red: 100%
green: 57%
blue: 14%
- if:
condition:
lambda: 'return id(alarm_panel_status).state == "triggered";'
then:
- light.turn_on:
brightness: 100%
effect: "Alarm Event Triggered"
- globals.set:
value: '1'
else:
- if:
condition:
lambda: 'return id(trigger_status) == 1;'
then:
- globals.set:
value: '0'
- light.turn_off:
- id: sensor_open_check
then:
- if:
condition:
lambda: 'return id(alarm_panel_status).state == "disarmed";'
then:
- if:
condition:
lambda: 'return id(all_sensors).state;'
then:
- light.turn_on:
brightness: 25%
red: 100%
green: 75%
blue: 0%
else:
- light.turn_off:
