Does anyone have AdGuard Home working with Google Wifi? I currently have AdGuard installed on Home Assistant and I’m able to reach it via the addon as well as web (https). I’ve read mix results. If someone has this up and running on their Google Wifi, please provide the steps you took.
On the Google Home app, I have went to my Wifi and selected the following and saved settings
Network Settings → Advanced networking → DNS Settings →
Selected Custom Settings
Primary; adguard.ip.address
Secondary, 8.8.8.8
Primary IPV6, 2001:4860:4860::888
Secondary IPV6, I left this empty
I don’t have DHCP server enabled. I will work on that next but I have AdGuard Home running. It is blocking my filters. I will keep this runnning and see what happens in the next 24 hours. I’ve read that it might run into errors and stop my network. I will report back.
Everything is still working fine. I have not had any wifi issues. Under DNS Server Config, I set the rate limit to 0. I did read another Reddit post where someone did this with Google Wifi and it help resolve issues.
Hope this will help someone down the road.
