Adjust other players using Voice PE Volume Dial
Hi! I like the convenient volume dial on the Voice PE and would like to use it to control other media players’ (player provider) volume. Is there a way to link them directly or would I need to use the volume attribute of the Voice PE entity for that? If so, how would I best go about this?
You can link with automation in HA
Could use some help with this. Template Editor shows the correct value for the attribute and the automation is being triggered when I change the volume but it is not setting the target volume:
alias: Volume Match
description: ""
triggers:
  - trigger: state
    entity_id:
      - media_player.home_assistant_voice_0a0524_media_player
    attribute: volume_level
conditions: []
actions:
  - action: media_player.volume_set
    metadata: {}
      attribute: >-
        state_attr('media_player.home_assistant_voice_0a0524_media_player','volume_level')
      entity_id: media_player.squeezeplay_b8_27_eb_9a_cd_e4
mode: single
replace the media players below. you can target multiple
alias: set volume
description: ""
triggers:
  - trigger: state
    entity_id:
      - media_player.hav_0a0f27_media_player_2
conditions: []
actions:
    metadata: {}
      volume_level: "{{ state_attr('media_player.hav_0a0f27_media_player_2', 'volume_level') | float }}"
      entity_id: media_player.voicewave_db28e8
mode: single
