I’m going to change the setup of some of my power monitoring which is going to throw off my energy dashboard. I’ve found the hourly values in the database under statistics. Can I just adjust the last value (Highest value) or do I need to go through and adjust all the of the values?
I need to adjust the values as I currently have 2 sets of power monitoring on the same circuit which just isn’t working, so I’m going to seperate them.
They all show 0 in the statistics adjustment tool, so I can’t adjust from there:
Can you give a little more information on what you have and what you are planning to do?
What role does the energy dashboard play and which values do you expect to change/mess up.
If you switch the hardware you can leave the sensors inactive in the configuration and they will keep the history.
