Adjusting the time in NetAlertX!
Hi, I need ideas to set the time correctly in NetAlertX. The time zone is correct, but it’s stubbornly one hour ahead. It’s correct in both Proxmox and Home Assistant. It might be a daylight saving time issue!
You could be dealing with a UTC Offset, which yes, could be a DST (or even a SDT) thing you’ve got to be mindful of. Double-check your time zone here.
It’s resolved. Using the add-on, the location was correctly set to Europe/Lisbon, but in the Netalertx settings, the timezone was set to Europe/Berlin. Thank you.
