In AHCv4 in the scheduler section.
In AHCv5 (current test version) it has an own prominent section.
Hi, Iād love to do that just donāt know how without setting all my automations up once again. I have the blueprint from the āadvanced heating controlā repository which is still at that version. The newer one is in the ādevā repository but then I get a different blueprintā¦
i will try that, but its still strange, because the calibration delta is set to 0,3 and calibration timeout to 5min!
I had a look to the log section and figured out, that there is no log for the calibration with v5!
You can copy the content of the dev file and paste it in your local blueprint. Then just press c anywhere in home assistant and type automation for reloading the blueprint. But check the config please. Maybe there a some additional selectors.
Yes, generic calibration runs over the normal set temperature branch. Iāve added some more logging information to the temperature change actions including trigger ids. Trigger ids for calibration or aggressive mode have the these key words in their IDs. Donāt forget to set debug level to warning if you havenāt done yet.
yes that was the mistake in my v5 automationā¦
What is this supposed to achieve?
As I said. I have to know what action call produce the error in your thermostat. So maybe the numbers have the wrong step size or your calibration entity consumes integer only.
In AHC are only 3 service calls. One for calibration, one for setting the hvac mode and one for setting the temperature.
But remember here are a lot more users with your thermostat without any issues who using this blueprint.
here the logs:
{ ātraceā: { ālast_stepā: āaction/2/default/4/if/condition/0ā, "run - Pastebin.com
{ ātraceā: { ālast_stepā: ācondition/0/conditions/3ā, ārun_idā: "e1 - Pastebin.com
Do you also can share the history graph of your thermostat and temperature sensor for the timestamp youāve taken the trace logs?
Yes, itās the generic calibration. You see the difference of the measured temperature by thermostat and room temperature is around 3Ā°C.
Your target is 18Ā°C. 18Ā°C + 3Ā°C = 21Ā°C. But as you can see the room temperature drops slowly. Just wonder if your radiator is warm at this point. If you want steeper heating curves, you can counteract this with the aggressive mode.
alright, thank you. i will test the aggressive mode
Maybe you go a little lower with the calibration delta, e.g. 0.3
//EDIT:
@ajb538
Iād tested it with v5 (current dev) and did some fixes. Feel free to test but I think I will release it as stable these days.
I have now tried everything to trigger the calibration and it just doesnāt do anything:
- I have exchanged my blueprint to the latest dev version
- I have renamed the calibration entity (Iām quite confident that it is in fact the calibration entity) of my Ally so that it is absolutely unique, and then I have put part of this name in the blueprint as calibration keyword, so that there cannot be any confusion
- I have tried several settings, such as covered vs. uncovered mode, manually setting a calibration temperature, using float vs. integer input, etc.
- I reduced calibration timeout to 10 sec. and delta to 0,1 Ā°C, so both are really low and should not prevent calibration. My external temperatures are way more off and sometimes donāt change over several hours.
ā¦but the calibration value just never changes. It stays where I set it manually, without changing - ever.
Unfortunately, in the new AHC sensor that was issued with the dev version, there is no ālast_calibrationā attribute anymore, so I cannot verify a calibration date, but I assume that would be empty.
Calibration should work also while the scheduler is in Eco, not only during Comfort, right?
Could it be possible that the HA quirk in ZHA for the Allys causes some malfunction of the calibration? How can I make sure that it doesnāt?
Is anybody reading this thread with Danfoss Allys, so that we can compare settings?
Latest trace is here:
https://controlc.com/bb387653
Thank you very much - any help will be much appreciated!
Iāve improved the sensor and updates the dev version. Could you update both and refresh the automations and template entities?
Yes
Maybeā¦ Could you try to set a calibration value by an action call in dev settings? (Please check your entity_id) The execution button should flash green and after that please verify the entity value has changed to the value in the service call.
Could you also check if the entity consumes integers? Maybe there is something different. I think the person who test with me the calibration last year did use z2m. Maybe the calibration property gets exposed differently.
action: number.set_value
value: 2100
entity_id: number.thermostat_bad_externer_temperatursensor_2
//EDIT:
Also check the return value of your manufacturer please. (paste this in your template editor)
{{ device_attr('climate.thermostat_bad_thermostat_2', 'manufacturer') }}
I could not set the calibration value using a four-digit integer ā1700ā, because that was out of the allowed range (-80 to 35).
But ā17ā worked and that set the value to 17,0 Ā°C. A floating value was also possible, but it required a dot instead of a comma (17,5 did not work, 17.5 worked).
The return value is: Danfoss
Thanks again!
Ok, thank you. Could you navigate here and filter for your number entity? A screenshot with all attributes would be helpful.
Could you update to the latest version and test again?
