thank you, file updated
No thank you for all your hard work setting up the blueprint. Glad I could help
I have android pixel but when I click on any of the options (taken / ask later / skip) it is not recorded. So after the reminder I get a new notification. I click always on taken but for some reason it’s not send back to HA.
Hi Same problem as above with my wife Samsung s21. When i took a look at the blueprint the IOS version and the Android version are the same!
The Android Version of the blueprint is not correct (it is for IOS)
Agreed. PR here:
merged, thank you for the fix
Still not working for me.
When I click any button (Taken, Ask Later or Skip) I get immediately a new notification. So it seems it’s in some kind of a loop.
Is your input boolean turned on when you select “taken”?
It needs to be “on” to start I believe. The trigger turns it off, then if “taken” is selected it should turn back on.
At least I think that is the case, this is day 1 of my use on this.
Made a new automation, put it on. Put same … once the automation runs it’s keep getting the notification no matter which option I click.
Uninstall the blueprint and automation restart home assistant install blueprint then make your automation.
This is the working blueprint for Android…
blueprint:
name: Advanced medication reminder
description: Get advanced notification and history for medication reminder
domain: automation
input:
reminder_time:
description: At what time do you want to be reminded
selector:
time: {}
notify_device:
description: Device needs to run the official Home Assistant app to receive
notifications
selector:
device:
integration: mobile_app
multiple: false
input_boolean:
name: Dedicated input_boolean
description: Create and set here a input_boolean to handle history and state
of the automation
selector:
entity:
domain: input_boolean
multiple: false
notification_title:
name: Notification title (Optional)
description: 'Default: Medication reminder'
default: Medication reminder!
notification_message:
name: Notification message (Optional)
description: 'Default: It''s time to take your medication'
default: It's time to take your medication
notification_action_taken:
name: 'Notification action: Taken (Optional)'
description: 'Default: Taken'
default: Taken
notification_action_later:
name: 'Notification action: Ask later (Optional)'
description: 'Default: Ask later'
default: Ask later
notification_action_skip:
name: 'Notification action: Skip (Optional)'
description: 'Default: Skip'
default: Skip
ask_later_wait_time:
name: Wait time before next reminder
description: Minutes before notify again after a Ask later action.
default: 30
selector:
number:
min: 5.0
max: 1440.0
unit_of_measurement: minutes
mode: slider
step: 1.0
logbook_message_remind:
name: Logbook message for remind (Optional)
description: 'Default: Reminder sent'
default: Reminder sent
logbook_message_taken:
name: Logbook message for action Taken (Optional)
description: 'Default: Medication taken'
default: Medication taken
logbook_message_later:
name: Logbook message for action Ask later (Optional)
description: 'Default: Postpone reminder'
default: Postpone reminder
logbook_message_skip:
name: Logbook message for action Skip (Optional)
description: 'Default: Reminder skipped'
default: Reminder skipped
logbook_message_no_answer:
name: Logbook message for no action after timeout (Optional)
description: 'Default: No answer time out'
default: No answer time out
optional_action:
description: Run an action like notify a speaker at the same time that the mobile
notification
selector:
action: {}
default: []
source_url: https://raw.githubusercontent.com/Aohzan/hass-blueprints/main/blueprints/medication_reminder.yaml
- platform: time
at: !input reminder_time
mode: restart
- service: input_boolean.turn_off
entity_id: !input input_boolean
- alias: Notify until the medication has been take
repeat:
while:
- condition: state
state: 'off'
sequence:
- service: logbook.log
name: !input notification_title
message: !input logbook_message_remind
- choose:
- conditions: '{{ true }}'
sequence: !input optional_action
- device_id: !input notify_device
domain: mobile_app
type: notify
title: !input notification_title
message: !input notification_message
actions:
- title: !input notification_action_taken
action: taken
- title: !input notification_action_later
action: later
- title: !input notification_action_skip
action: skip
tag: !input input_boolean
- wait_for_trigger:
platform: event
event_type: mobile_app_notification_action
event_data:
timeout:
minutes: !input ask_later_wait_time
- choose:
- conditions: '{{ wait.trigger and wait.trigger.event.data.action == ''taken'' }}'
sequence:
message: !input logbook_message_taken
- conditions: '{{ wait.trigger and wait.trigger.event.data.action == ''later'' }}'
sequence:
message: !input logbook_message_later
- delay:
- conditions: '{{ wait.trigger and wait.trigger.event.data.action == ''skip'' }}'
sequence:
message: !input logbook_message_skip
default:
domain: mobile_app
type: notify
message: clear_notification
message: !input logbook_message_no_answer
I rollback the missing default part at the end, I pushed the update, sorry
Removed the blueprint, restarted Home Assistant. Imported the Blueprint again via this link : hass-blueprints/medication_reminder_android.yaml at 0092094776715d880e0eff3b0d2b54807dbd50aa · Aohzan/hass-blueprints · GitHub
But still not solved. Input Boolean I have put on.
When automation runs it’s put to off. But then again no mater which option I click the notification pops up again immediately.
Log of the input Boolean:
Reminder sent getriggerd door automatisering Notificatie ImmuDefense innemen getriggerd door tijd
11:01:20 - 2 minuten geleden
No answer time out getriggerd door automatisering Notificatie ImmuDefense innemen getriggerd door tijd
11:01:17 - 2 minuten geleden
11:01:12 - 2 minuten geleden
11:01:06 - 2 minuten geleden
11:01:00 - 2 minuten geleden
Is uitgeschakeld getriggerd door automatisering Notificatie ImmuDefense innemen getriggerd door tijd
Is ingeschakeld getriggerd door service input_boolean.turn_on
10:57:21 - 6 minuten geleden - Yves
The Blueprint config
alias: Notificatie ImmuDefense innemen
description: Notificatie voor Yves voor het innemen van ImmuDefense
use_blueprint:
path: Aohzan/medication_reminder_android.yaml
input:
reminder_time: '11:01:00'
notify_device: f1e469f41a3ad819a0b437bcb88b7d9d
input_boolean: input_boolean.yves_immudefense
notification_title: Medicatie herinnering
notification_message: Neem 1 pil ImmuDefense
notification_action_taken: Ingenomen
notification_action_later: Uitstellen
notification_action_skip: Overslaan
The automation:
- platform: time
at: '11:01:00'
mode: restart
entity_id: input_boolean.yves_immudefense
repeat:
while:
- condition: state
state: 'off'
sequence:
name: Medicatie herinnering
message: Reminder sent
- choose:
sequence: []
- device_id: f1e469f41a3ad819a0b437bcb88b7d9d
domain: mobile_app
type: notify
actions:
- title: Ingenomen
action: taken
- title: Uitstellen
action: later
- title: Overslaan
action: skip
tag: input_boolean.yves_immudefense
- wait_for_trigger:
platform: event
event_data:
timeout:
minutes: 30
- choose:
- conditions: >-
{{ wait.trigger and wait.trigger.event.data.actionName ==
'taken' }}
sequence:
message: Medication taken
- conditions: >-
'later' }}
sequence:
message: Postpone reminder
- delay:
minutes: 30
- conditions: >-
{{ wait.trigger and wait.trigger.event.data.actionName == 'skip'
sequence:
message: Reminder skipped
default:
domain: mobile_app
type: notify
message: No answer time out
Trace timeline
Triggered by the time at 18 november 2022 om 11:01:00
Boolean invoer: Turn off Yves ImmuDefense
(input_boolean.yves_immudefense) turned off
unknown
Medicatie herinnering (input_boolean.yves_immudefense) Reminder sent
7 seconden later
unknown
Medicatie herinnering (input_boolean.yves_immudefense) No answer time out
5 seconden later
unknown
5 seconden later
unknown
3 seconden later
unknown
Still running
Copy and paste the blueprint code i posted above into file: blueprints/automation/Aohzan/medication_reminder_android.yaml
restart home assistant. This should work.
The default action at the bottom of the blueprint on github is not in the correct format (i think)
It is working now with the code as you have mentioned, thanks!
Your welcome
