Advantage Air - change IP
Many integrations have a Configure capability which allows you to reconfigure what was chosen at setup.
The Advantage Air integration asks for IP and port at setup, but then does not provide a way to change that later without removing/re-adding.
I’m about to have to undertake a major network change and realised this…
Is there a way to change the IP that the integration looks for the A/C tablet at? Can a request be added for this if not?
Check this one. Have to go into terminal and can adjust it there.
