At this time, I have Mosquitto running as an app in home assistant; it’s a docker app configured to start at boot and watchdog is watching it. I also have Zigbee2MQTT as an app, same thing, start at boot, watchdog enabled. My home assistant is running as a proxmox VM with 8 vCPU’s and 12GB memory, in my estimation it’s fairly over-resourced.
I’ve been having multiple family-impacting failures lately where Zigbee2MQTT fails so the lights don’t work, and when I investigate, most of the time it’s because Mosquitto stopped and didn’t restart. When I open the mosquitto logs, there’s nothing in there other than a shutdown that doesn’t auto restart, relevant snippet below:
2026-02-25 02:10:40: New client connected from 10.5.9.101:58841 as DVES_038E3B (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_388856 already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.148:52597 as DVES_388856 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_8D95AF already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.144:64704 as DVES_8D95AF (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_388280 already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.147:55264 as DVES_388280 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_D28D10 already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.122:51785 as DVES_D28D10 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_E3512D already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.107:60614 as DVES_E3512D (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_5FE2B9 already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.123:56333 as DVES_5FE2B9 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client 4Ls0qTrSs1OTvfpd2axHDZ already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 172.30.32.1:58413 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: Client <unknown> closed its connection.
2026-02-25 02:10:40: New client connected from 172.30.32.1:48027 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 172.30.32.1:43515 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 172.30.32.1:40027 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_6E40CB already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.121:63842 as DVES_6E40CB (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_B1C2BF already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.146:55511 as DVES_B1C2BF (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_B2346D already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.149:61322 as DVES_B2346D (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 172.30.32.1:33069 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_CE5E7A already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.102:59227 as DVES_CE5E7A (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_CF2324 already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.103:52435 as DVES_CF2324 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_CEF3A5 already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.104:49635 as DVES_CEF3A5 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 172.30.32.1:46305 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_038E3B already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.101:52670 as DVES_038E3B (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_8D9124 already connected, closing old connection.
2026-02-25 02:10:40: New client connected from 10.5.9.143:64838 as DVES_8D9124 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 10.5.9.144:62039 as DVES_8D95AF (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 10.5.9.147:58485 as DVES_388280 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 10.5.9.122:63505 as DVES_D28D10 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 10.5.9.107:61065 as DVES_E3512D (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 10.5.9.148:52139 as DVES_388856 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 10.5.9.123:59186 as DVES_5FE2B9 (p2, c1, k30, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 172.30.32.1:43371 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 172.30.32.1:55213 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: New client connected from 172.30.32.1:43361 as 4Ls0qTrSs1OTvfpd2axHDZ (p2, c1, k60, u'mqtt-user').
2026-02-25 02:10:40: Client DVES_6E40CB closed its connection.
2026-02-25 02:10:40: Client DVES_B1C2BF closed its connection.
2026-02-25 02:10:40: Client DVES_B2346D closed its connection.
2026-02-25 02:10:40: Client DVES_CE5E7A closed its connection.
2026-02-25 02:10:40: Client DVES_CF2324 closed its connection.
2026-02-25 02:10:40: Client DVES_CEF3A5 closed its connection.
2026-02-25 02:10:40: Client DVES_038E3B closed its connection.
2026-02-25 02:10:40: Client DVES_8D9124 closed its connection.
2026-02-25 02:10:40: Client DVES_8D95AF closed its connection.
2026-02-25 02:10:40: Client DVES_388280 closed its connection.
2026-02-25 02:10:40: Client DVES_D28D10 closed its connection.
2026-02-25 02:10:40: Client DVES_E3512D closed its connection.
2026-02-25 02:10:40: Client DVES_388856 closed its connection.
2026-02-25 02:10:40: Client DVES_5FE2B9 closed its connection.
2026-02-25 02:10:40: Client 4Ls0qTrSs1OTvfpd2axHDZ closed its connection.
s6-rc: info: service legacy-services: stopping
2026-02-25 02:10:40: mosquitto version 2.0.22 terminating
2026-02-25 02:10:40: Saving in-memory database to /data//mosquitto.db.
[10:10:40] INFO: e[32mService restart after closinge[0m
s6-svwait: fatal: timed out
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
[10:10:45] INFO: e[32mService restart after closinge[0m
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
This is happening about twice a week. Additionally, I find my actual Home Assistant VM takes forever to reboot, sometimes up to 20 minutes.
I’ve been considering just taking mosquitto and making it a separate VM. It may be more relevant if I use MQTT for more things (like Meshtastic), and I am wondering if it will help take some resource load off of HA. That being said, before I go that route I want to know if anyone has any advice for if there is a better fix; I’ve installed MQTTExplorer and cleaned a bunch of topics out that were for devices that no longer exist (An old smart camera system I replaced had a bunch of crap in there).
