I am looking for recommendations on a air quality monitor that works with HA.
I’m based in the UK, something easy to purchase here and sensibly priced. (No additional hub required). I already have Wi-Fi devices and Zigbee available.
As a minimum I want Carbon Dioxide (CO2), other air quality monitoring sensors would be a bonus.
I don’t have the time at the moment to buy components and build one for ESPHome, so needs to be available off the shelf and pretty much plug and play.
Exactly. If they are sensibly priced, they are probably inferring CO2 from a cheaper sensor like VOC and no good.
I chose to buy a Netatmo weather station with several indoor units. Not cheap, but if you get a discounted set you will have a good weather station as well, so the price is easier to justify.
I also own an Awair Element, which has a nice combination of sensors and a nice case with easy to read display. During Covid the price spiked to the absurd, I do not know if it returned to normal.
I also own some Apollo Air1 devices. You can somewhat choose which sensors you want. They offer a broad selection of sensors. Note that CO and Methane can react to other gasses as well. Use an aerosol nearby and both will spike.
I think all very good choices, but none are sensibly priced.
Note that I think that CO2 sensors are very much worth the investment though. Most people do not realize they have headache inducing levels in rooms they are in. If you have teenagers who keep their windows and room door closed a lot you’ll definitely lean to appreciate them. That is partly why I have so many.
It is a wifi indoor base station (proprietary connection to other units), cloud based, a downside I forgot to mention. You can use Homekit for local access though, but for me that proved less reliable. I still have it as a backup.
The Awair element allows for local wifi access if you enable it. The Apollo is local wifi.
EDIT: I checked and it seems from history the Homekit integration with Netatmo is pretty stable now. Maybe I experimented with it at a time it was a bit buggy?
Not trying to derail the thread, but what exactly is your end goal for the sensor? There’s a lot of misconceptions when it comes to indoor CO2 levels and there may be cheaper/easier ways to achieve what you’re after. Long/short: CO2 levels have to be HIGH for it to ever actually be an issue or concern; the only real reason for measuring it indoors is using it as a proxy for occupancy.
I strongly disagree. These are real life measurements from a room where a teenager lives. Those spikes are enough to make you feel bad. The drops are when windows are opened to counteract. And it has been worse… I tell my kids to ventilate, they won’t listen, but they do listen when they see this. The joys of puberty…:
It may differ how well the house is insulated though, and if you open windows regularly. People often forget to open windows and they should do that often. I live in a normal, modern, highly insulated house.
Those are normal fluctuations I’d expect to see based on occupancy, but it’s nowhere near any kind of dangerous limits. As an example, OSHA (the US’s workplace safety agency), anything under an AVERAGE of 5,000 PPM is considered fine.
When folks report feeling the effects of high CO2 levels, it’s generally other pollutants (or honestly, just odors) in the air causing this and of course is very real. Fresh air is great, but it’s also very energy-intensive to condition that air, so it’s important to only bring in the minimum you really need (outside of when the weather is amazing outside, of course ). Where I live, we really only get a few weeks of weather like this but I always look forward to opening up the house as much as possible.
You may very well be right. But if in real life these CO2 levels are always accompanied by other contaminants inducing headache and other ill effects, then it is a very useful indicator. Even if the CO2 level itself, in isolation of other contaminants, is safe. Because that is a useless lab situation.
The ill effects on the people are real, and the CO2 levels are the only sensor that correlates to it. That is real life experience. And as you can tell from the posts above, I have loads of air quality sensors. Both useful ones and senseless ones. I can honestly tell you the CO2 ones are the only ones I really care about, because they serve a real purpose.
By saying these levels I show are “normal” to see in homes you prove my pijnt. Because when the spikes happen, air in those rooms is actually bad. I’d rather follow recommended levels for classrooms. The levels shown here are used by many European governments as well:
I find myself getting very tired and lethargic in the afternoon, while working in my home office (a small box room with a tiny 50cm square window that is at head height).
I’m concerned that perhaps CO2 is becoming high. It should be an easy thing to check, with a reasonable bit of kit.
Would also like to see how CO2 is overnight in our bedroom.
Its a timber frame house built with a log of insulation, so pretty airtight.
I decided to purchase the MSR-2 monitor, which has now been in use for a week.
I seem to be regularly getting up close to 2,000ppm CO2, once up to almost 3,000.
Looking online at recommendations, this is definitely getting into the numbers to cause drowsiness.
I would also like to mention the Airgradient One. The hardware and software are open source, designed for purely local communication and has the ‘Works with Home Assistant’ logo (or will soon have it).
Only high-quality sensors have been installed whose reliability and accuracy have been optimised in various studies with universities. And at a relatively favourable price. The kit, where you only have to plug the sensors onto the board, is available from USD 138.
And since it is open source and an ESP32 is used, the air gradient can also be easily customised with ESPhome, for example what should be shown on the display or how the coloured LEDs should behave. Advantage: you can do it, but you don’t have to. So I think the device is perfect for anyone looking for a plug and play solution out of the box, as well as for anyone who wants to realise individual requirements.
I’ve been experimenting with ESPhome and various sensors and displays for a while. The result was very satisfactory, even if you don’t want to solder. But there is still the problem of a proper housing that you want to have in your living room. I don’t have a 3D printer for that.
The only disadvantage of the Airgradient is the somewhat large housing and the small display. Nevertheless, I’ve ordered one for indoor and outdoor use and think it could be the device that best meets my requirements. But I will also try out the Apollo.
