I have a traditional outdoor PIR sensor, this is wired into a Zigbee switch module.
If the PIR (which is set to work in daylight too) detects somebody, the Zigbee switch goes on.
Zigbee entity is called ‘light.carport_pir’ and is turned on with motion (PIR is set to min activation time, so <1 min).
I have a Ecowitt weather station which includes a Solar Lux sensor, called ‘sensor.gw1200a_solar_lux’, once its below say 50 then it’s dark outside.
I also have a Tuya Wi-Fi LED flood light ‘light.carport_led’ connected via Tuya Local.
Can I create a automation for the PIR to trigger the LED on with a preset brightness level and colour only if the Lux is <50? Stay on for 5 mins and then go back off again.
Can this be done via the wizard, and not via YAML?
I have tried via the GUI and can successfully select ‘When’ and CarPort_PIR turned on - but I cannot seem to find the Lux sensor to set a ‘And if’ value.
Thanks in advance ![]()
