I am planning to integrate my Daikin ducted HVAC (VRV with 2 outdoor units, 9 indoor units, hot water box and radiant heating box) with Home Assistant using an Intesys gateway IN770AIR00SO000.
The Intesys gateway offers a choice of integration protocols, any of which could be made to work with Home Assistant:
BacNet (I must admit I have not explored this route properly)
Does anyone have any experience of the tradeoffs with these different integrations in a similar scenario that might help inform my choice? I’d rather avoid installing a bridge if I can, so I lean toward the WMP/Modbus options, but if it’s worth the effort I can do KNX.
No hands-on experience with the mentioned HVAC, however unless the HACS integration had a very active development and active community, I would go with one of the official integrations.
In case anyone is interested, I have decided to use modbus, because:
KNX seems to require proprietary software
BacNet seems pretty complicated and over the top for my needs
The WMP integration is missing some important controls (like DHW control for example).
I am going to try using the modbus2mqtt add-on to simplify data acquisition.
I won’t be able to organise the hardware installation for a while but will report back when I have some news…
I plan to test out some protocols when I get some free time and the end of the month. Will take a good look at this and MQTT - Bacnet looks to offer a fuller integration but it’s all new for me.
Well in the end I tried MQTT first as I was most familiar with it. It took a lot of trial and error but I now have a full-featured AC integration with 11 indoor units, DHW, radiators and underfloor heating. Works flawlessly. The intesis 770 unit is excellent and a huge upgrade over the Daikin iTab controller system (which couldn’t even control hot water production and has no API or automation capability). Would recommend!
