Advice on purchasing a Zigbee TRV
Can you recommend some ZigBee thermostatic valves? I need to install them on four radiators. What are the Sonoff ones like? Thanks.
Hi Marcello, I have installed 1 Sonoff 6 months ago and so far I’m happy with it.
Batteries still at 100%.
Planning to add a few more in the coming days.
model sonoff TRVZB ?
Aqara is coming out with a new model (W600 ) that should do the job.
Yes, that’s the one.
I‘ve replaced 10 Eve Thermo with Sonoff TRVZB a year ago and really like the hardware and regulation. Plus it‘s one of the few devices that allow direct control of the valve opening percentage.
Hello MarcelloTT,
I also suggest doing this search and looking at the other recent responses to similar questions.
Search is your friend sometimes.
Search results for 'TRV tags:recommendations' - Home Assistant Community
I installed 4 of these sonoff’s. I use external temperature function and i send room temperatures from Xiaomi sensors one the other side of the room into sonoff with HA automation. Works great (so far), when sonoff’s hysteresis is set to 0.4 degree room temp is indeed in the range of one degree top-bottom difference max (but mostly even less).
