Advice to add connected valves to KNX heating system
I’m considering adding connected valves to complement an existing KNX thermostat (I have 3 other thermostats that are mainly focused on specific areas and ok for my use).
The concerned thermostat is located in one room but also controls radiators in 3 other rooms.
I would like to have more control on the heating in these rooms by controlling the different concerned radiators (eg shutting the valve of the main room radiator while opening the valve of the radiator of another concerned room).
Would it be possible to use radiator valves like those of Tado or Netatmo in combination with my existing KNX thermostat?
Thanks already for advice.
