Advice to make 2 row Layout Card
Layout card looks super powerful, but also very complex. I’m not getting it work work the way I need. (yaml code on pastesio)
thx for the help!
Use Case : mobile devices
Goals…
2 rows, 1st row 2 columns, 2nd row one horizontal scrolling column.
1st row, 1st column : contains the custom-buttons to set the entity for the conditionals
1st row, 2nd column : controls for the shade_group (based on the conditional set)
2nd row : scrolls independently of the rest of the screen/page. Shows individual shade controls (based on the conditional set)
If you have done, or seen, some examples please point to the code… I learn best by seeing example code. thank you!
I’d use custom layout card instead, as it makes defining cards position within dashboard more flexible and has tons of customization options. The the code would be:
type: custom:layout-card
layout_type: grid
layout_options:
  grid-template-columns: 50% 50% # defines columns width, can use fr, px, % or auto
  grid-template-rows: auto auto # defines row heigth, can use  px or auto (not sure about % and fr)
  grid-template-areas: |
    "1 2"  # in first row you have 2 cells defined, called 1 and 2, any distinctive name can be used
    "3 3" # in second row you have 1 cell defined,  that spans across 2 columns
cards:
  - type: card 1 # here the first card goes, anything you want
    view_layout:
      grid-area: 1 # this defines where the card will be placed within the grin, in this case cell named 1
    card content
  - type: card 2
    view_layout:
      grid-area: 2
    card content
  - type: card 3
    view_layout:
      grid-area: 3
    card content
Bonus: for more advanced setup you can also use mediaquery to define different grid layouts for different screen sizes, so you can use one dashboard for regular screens and mobiles, that will adjust layout depending on what device is used to display it.
thank you, that helped a lot… template-areas was what I was not getting right in my code.
Ideally, the 1st row would always be onscreen as 2 columns, and the 2nd row would scroll independently so show all 4 columns.
… Do you know how to get the 2nd Row to expand and scroll?
Also, its still squashing the cells in the 2nd row on only the phone.
here’s the tablet (works as expected)…
here’s the phone, notice the shade image is missing. This only happens with a set of 4 shades, when there are 2, it works perfectly. How it looks…
When I force a specific width to try to make it always show the shade image, it expands the cells too much if there are only 2 cells – they will fill the 4 columns instead of staying as 2 columns
grid-template-columns: 220px 220px 220px 220px
grid-gap: 14px
“1 2”
“3 3 3 3”
Or change this code to:
grid-template-columns: 25% 25% 25% 25%
    "1 1 2 2"
    "3 4 5 6"
and put you shade cards to cells 3 to 6…
@mirekmal
with you and some AI, and 3 hours trying different things, I’m almost there.
I have it all working except 1 thing… how to make Row 2 scroll, while Row 1 stays static; cant find info on this?
I do not think it is possible. Perhaps with some card mod and CSS tweaking? I was also in search for creation of non scrollable part of dashboard, but never found the solution :frowning:
@mirekmal Take a look at the CSS command overflow: specifically overflow-y:
@Ltek Here is a simple example.
type: custom:enhanced-shutter-card
entities:
  - entity: cover.xxxxxxx
  - entity: cover.yyyyyyy
card_mod:
  style: |
    ha-card {
    height: 200px;
    overflow-y: scroll;
Perhaps it works with selected cards. I just tried to use it on huge vertical stack and it only clips the content to given height, but soe not scroll content. Here is the code I used:
type: custom:vertical-stack-in-card
card_mod:
  style: |
    ha-card {
    height: 500px;
    overflow: scroll;
cards:
  - type: entities
    entities:
      - input_select.uptimekuma_period
  - type: custom:text-divider-row
    text: OVERALL AVAILABILITY
  - type: custom:decluttering-card
    template: uptime
    variables:
      - entity: sensor.uptimekuma_192_168_52_21
    text: NETWORK
    template: uptime
    variables:
      - entity: sensor.uptimekuma_mirekmal_dns
    template: uptime
    variables:
      - entity: sensor.uptimekuma_cable_modem
. . . # entire list contains ~80 card like one above for monitored entities
The code causes entire stack to be clipped and static, not scrolling the content.
Interestingly, if I replace custom stack with native one it is even not clipped…
It’s not overflow: scroll; it is overflow-y: scroll !important;
What do you get with this?
card_mod:
  style: |
    ha-card {
    height: 200px;
cards:
  - type: entities
    entities:
  - type: entities
    entities:
  - type: entities
    entities:
  - type: entities
    entities:
overflow: scroll will add both horizontal and vertical scrollbars. Adding !important will force the CSS mod
Ha! Apparently !important was important :wink:
I tried previously both overflow and overflow-y and result was exactly the same. Making it important made the change. Thanks a lot!
I tried that an has found a few issues…
  1. must use “custom: stack-in-card”; the built-in “horizontal-stack” doesnt work.
  2. I see scroll bars when on my PC’s large-screen (not sure why since they cannot be used, are not needed) but no scroll bars are on my phone screen (where they are very needed)
  3. the stack-in-card is always panning the 4 columns, even when it only needs 2 columns since only 2 entities are defined. this will force a scroll bar to always show, and simply looks bad too.
full YAML here
hoping you might have some solutions? thanks for the help!
One more hint, I found, regarding vertical sizing of scrollable area, to dynamically adjust size while resizing browser window:
    card_mod:
      style: |
        ha-card {
        height: calc(100vh - 230px);
This takes total heigth of browsing area (100vh) ans substracts heigth on non scrollable part of screen/header (230px) to calculate size of scrollable part of window.
I cant get the horizonal scroll to work on mobile at all… it just is the normal swipe, moving then entire screen, not the inset/wrapper area. Its unfortunate that the dashboard is so capable but such a hack of multiple things even just to get basic layouts like I’m trying to do. If dashboards were simply 100% standard HTML/CSS with embedded calls to HA objects we could have simply used a standard web editor to create dashboards with 100x less trouble.
dashboard layouts are a serious nightmare… grid-layout doesnt work the way the docs say in the CSS docs.
I have tried using multiple methods to SIMPLY get this YAML to have 4 columns, and the first two items in Row 1, Columns 1 & 2 (leave 3 & 4 empty)
Then the other cards in the 2nd row (2 or 4 cards) to simply fill in 1-2-3-4, as needed
it doesnt work.
type: custom:grid-layout
icon: mdi:roller-shade
path: shades-scroll
title: Shades-scroll
layout:
  grid-gap: 0px
  grid-template-columns: 190px 190px 190px 190px
    "B B G G"
    "C1 C2 C3 C4"
cards:
  # Left column buttons (spanning both rows)
  - type: vertical-stack
    view_layout:
      grid-column: B
    cards:
      - type: custom:button-card
        entity: input_select.shades_group_display_selector
        show_icon: false
        tap_action:
          action: call-service
          service: input_select.select_option
          service_data:
            entity_id: input_select.shades_group_display_selector
            option: Kitchen
        state:
          - value: Kitchen
            styles:
              card:
                - background-color: var(--primary-color)
        styles:
          card:
            - padding: 8px
            - font-weight: normal
            - font-size: 18px
            - justify-content: center
            - text-align: center
            - border-radius: 8px
        show_icon: false
        tap_action:
          service_data:
            option: Living Room
        state:
          - value: Living Room
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
        show_icon: false
        tap_action:
          service_data:
            option: Play Room
        state:
          - value: Play Room
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
        show_icon: false
        tap_action:
          service_data:
            option: Master Bedroom
        state:
          - value: Master Bedroom
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
        show_icon: false
        tap_action:
          service_data:
            option: Master Bathroom
        state:
          - value: Master Bathroom
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
        show_icon: false
        tap_action:
          service_data:
            option: Guest Bedroom
        state:
          - value: Guest Bedroom
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
    card_mod:
      style: |
        ha-card {
          border: none !important;
          background: none !important;
          box-shadow: none !important;
  # Kitchen Cards
  - type: conditional
    conditions:
      - entity: input_select.shades_group_display_selector
        state: Kitchen
    card:
      scale_icons: false
      entities:
        - entity: cover.kitchen_shade_group
          name: All in Room
          disable_end_buttons: true
          window_image: esc-window.png
          shutter_slat_image: esc-shutter-slat.png
          name_position: bottom
          disable_partial_open_buttons: false
          always_percentage: true
          invert_percentage: false
          base_height_px: 120
          base_width_px: 40
      card_mod:
        style: |
          ha-card {
            max-width: 190px !important;
            border: 3px solid #FF5733 !important;
            border-radius: 8px !important;
            background: transparent !important;
      view_layout:
        grid-column: G
  - type: conditional
    conditions:
        state: Kitchen
    card:
      scale_icons: false
      entities:
        - entity: cover.shades_kitchen_tuya_ts0601_cover_1
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.shades_kitchen_tuya_ts0601_cover_1_battery
          signal_entity: sensor.shades_kitchen_tuya_ts0601_cover_1_linkquality
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C1
        grid-row: 2
  - type: conditional
    conditions:
        state: Kitchen
    card:
      scale_icons: false
      entities:
        - entity: cover.shades_kitchen_tuya_ts0601_cover_2
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.shades_kitchen_tuya_ts0601_cover_2_battery
          signal_entity: sensor.shades_kitchen_tuya_ts0601_cover_2_linkquality
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C2
        grid-row: 2
  # Living Room Cards
  - type: conditional
    conditions:
        state: Living Room
    card:
      scale_icons: false
      entities:
        - entity: cover.living_room_shade_group
          name: All in Room
          base_height_px: 120
          base_width_px: 40
      card_mod:
        style: |
          ha-card {
            border: 3px solid #33FF57 !important;
      view_layout:
        grid-column: G
  - type: conditional
    conditions:
        state: Living Room
    card:
      scale_icons: false
      entities:
        - entity: cover.shades_living_room_tuya_ts0601_cover_1
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.shades_living_room_tuya_ts0601_cover_1_battery
          signal_entity: sensor.shades_living_room_tuya_ts0601_cover_1_linkquality
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C1
        grid-row: 2
  - type: conditional
    conditions:
        state: Living Room
    card:
      scale_icons: false
      entities:
        - entity: cover.shades_living_room_tuya_ts0601_cover_2
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.shades_living_room_tuya_ts0601_cover_2_battery
          signal_entity: sensor.shades_living_room_tuya_ts0601_cover_2_linkquality
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C2
        grid-row: 2
  - type: conditional
    conditions:
        state: Living Room
    card:
      scale_icons: false
      entities:
        - entity: cover.shades_living_room_tuya_ts0601_cover_3
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.shades_living_room_tuya_ts0601_cover_3_battery
          signal_entity: sensor.shades_living_room_tuya_ts0601_cover_3_linkquality
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C3
        grid-row: 2
  - type: conditional
    conditions:
        state: Living Room
    card:
      scale_icons: false
      entities:
        - entity: cover.shades_living_room_tuya_ts0601_cover_4
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.shades_living_room_tuya_ts0601_cover_4_battery
          signal_entity: sensor.shades_living_room_tuya_ts0601_cover_4_linkquality
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C4
        grid-row: 2
  # Play Room Cards
  - type: conditional
    conditions:
        state: Play Room
    card:
      scale_icons: false
      entities:
        - entity: cover.playroom_shade_group
          name: All in Room
          base_height_px: 120
          base_width_px: 40
      card_mod:
        style: |
          ha-card {
            border: 3px solid #3357FF !important;
      view_layout:
        grid-column: G
  - type: conditional
    conditions:
        state: Play Room
    card:
      scale_icons: false
      entities:
        - entity: cover.shade_playroom1
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_playroom1
          signal_entity: sensor.somfy_shade_rssi_playroom1
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C1
        grid-row: 2
  - type: conditional
    conditions:
        state: Play Room
    card:
      scale_icons: false
      entities:
        - entity: cover.shade_playroom2
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_playroom2
          signal_entity: sensor.somfy_shade_rssi_playroom2
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C2
        grid-row: 2
  - type: conditional
    conditions:
        state: Play Room
    card:
      scale_icons: false
      entities:
        - entity: cover.shade_playroom3
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_playroom3
          signal_entity: sensor.somfy_shade_rssi_playroom3
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C3
        grid-row: 2
  - type: conditional
    conditions:
        state: Play Room
    card:
      scale_icons: false
      entities:
        - entity: cover.shade_playroom4
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_playroom4
          signal_entity: sensor.somfy_shade_rssi_playroom4
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C4
        grid-row: 2
  # Master Bedroom Cards
  - type: conditional
    conditions:
        state: Master Bedroom
    card:
      scale_icons: false
      entities:
        - entity: cover.master_bedroom_shade_group
          name: All in Room
          base_height_px: 120
          base_width_px: 40
      card_mod:
        style: |
          ha-card {
            border: 3px solid #33FFF0 !important;
      view_layout:
        grid-column: G
  - type: conditional
    conditions:
    card:
      scale_icons: false
      entities:
        - entity: cover.somfy_shade_masterbed1
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_master_bedroom_1
          signal_entity: sensor.somfy_shade_rssi_master_bedroom_1
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C1
        grid-row: 2
  - type: conditional
    conditions:
    card:
      scale_icons: false
      entities:
        - entity: cover.somfy_shade_masterbed2
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_master_bedroom_2
          signal_entity: sensor.somfy_shade_rssi_master_bedroom_2
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C2
        grid-row: 2
  - type: conditional
    conditions:
    card:
      scale_icons: false
      entities:
        - entity: cover.somfy_shade_masterbed3
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_master_bedroom_3
          signal_entity: sensor.somfy_shade_rssi_master_bedroom_3
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C3
        grid-row: 2
  - type: conditional
    conditions:
    card:
      scale_icons: false
      entities:
        - entity: cover.somfy_shade_masterbed4
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_master_bedroom_4
          signal_entity: sensor.somfy_shade_rssi_master_bedroom_4
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C4
        grid-row: 2
  # Master Bathroom Cards
  - type: conditional
    conditions:
        state: Master Bathroom
    card:
      scale_icons: false
      entities:
        - entity: cover.master_bathroom_shade_group
          name: All in Room
          base_height_px: 120
          base_width_px: 40
      card_mod:
        style: |
          ha-card {
            border: 3px solid #FF33F0 !important;
      view_layout:
        grid-column: G
  - type: conditional
    conditions:
    card:
      scale_icons: false
      entities:
        - entity: cover.somfy_shade_masterbath1
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_masterbath1
          signal_entity: sensor.somfy_shade_rssi_master_masterbath1
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C1
        grid-row: 2
  - type: conditional
    conditions:
    card:
      scale_icons: false
      entities:
        - entity: cover.somfy_shade_masterbath2
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_masterbath2
          signal_entity: sensor.somfy_shade_rssi_master_masterbath2
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C2
        grid-row: 2
  # Guest Bedroom Cards
  - type: conditional
    conditions:
        state: Guest Bedroom
    card:
      scale_icons: false
      entities:
        - entity: cover.guest_bedroom_shade_group
          name: All in Room
          base_height_px: 120
          base_width_px: 40
      card_mod:
        style: |
          ha-card {
            border: 3px solid #F033FF !important;
      view_layout:
        grid-column: G
  - type: conditional
    conditions:
    card:
      scale_icons: false
      entities:
        - entity: cover.somfy_shade_guest1
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_guest_bedroom_1
          signal_entity: sensor.somfy_shade_rssi_guest_bedroom_1
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C1
        grid-row: 2
  - type: conditional
    conditions:
    card:
      scale_icons: false
      entities:
        - entity: cover.somfy_shade_guest2
          base_height_px: 120
          base_width_px: 40
          battery_entity: sensor.somfy_shade_battery_level_guest_bedroom_2
          signal_entity: sensor.somfy_shade_rssi_guest_bedroom_2
      card_mod:
        style: |
          ha-card {
      view_layout:
        grid-column: C2
        grid-row: 2
You are testing with a custom button card which may not be properly adjusted for using in a grid. In my experience, at least in part of a height it should be adjusted by card-mod.
Test with a stock button.
Also, note that cards have own limitations for min number of rows and columns.
As Ildar pointed out, the `custom:button-card is a different animal. The card size can be controlled through several methods
for example:
size:
aspect:
styles:
     card:
        - width: ?px
        - height: ?px
Check out this thread
You also may want to research the @media CSS options for mobile formatting if you dashboard is not using the Sections format.
Zero problems with the button card, its the grid not placing the ‘other cards’… ive spent 4+ hrs reading css grid docs and ha docs, and 3+ more hours in AI and testing trying at at least 10 variations of codes and cards… im giving up.
You telling me im doing it wrong, yet no one does/can correct my code so i can learn… that leads to the logocal conclusion that HA dashboards arre a hackery even long tome experts find difficult. Unless you have ninja coding skills figuring out a disparate mish mash from multiple “languages” is ridiculously difficult. Dashboards need a complete ovehaul.
Hey all, trying this again if anyone can help I’d really appreciate it.
I’ve spent MANY hours on this just to get the below YAML working cleanly. BUT I still cannot get the 2nd row to scroll while keeping the 1st row static when the row changes from 2 to 4 entities. I have tried a million different things – using/not card wrappers, trying different CSS code, etc.
I want this view to work on any size device screen, so Row 1 must always stay ‘on screen’ and Row 2 must scroll when there are more than 2 entities in that row. This will allow the Room Switch buttons & ‘All in Room’ to always be visible.
path: shades
title: Shades
layout:
  grid-gap: 0px
    "1 1 2 2"
    "3 3 3 3"
cards:
    view_layout:
      grid-column: 1
      grid-row: 1
    cards:
        show_icon: false
        tap_action:
          service_data:
            option: Kitchen
        state:
          - value: Kitchen
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
            - border-radius: 4px
        show_icon: false
        tap_action:
          service_data:
            option: Living Room
        state:
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
        show_icon: false
        tap_action:
          service_data:
            option: Play Room
        state:
          - value: Play Room
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
        show_icon: false
        tap_action:
          service_data:
        state:
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
        show_icon: false
        tap_action:
          service_data:
        state:
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
        show_icon: false
        tap_action:
          service_data:
        state:
            styles:
              card:
        styles:
          card:
            - padding: 8px
            - font-size: 18px
  - type: horizontal-stack
    view_layout:
      grid-column: 2
      grid-row: 1
    cards:
      - type: conditional
        conditions:
            state: Kitchen
        card:
          scale_icons: false
          entities:
              name: All in Room
              base_height_px: 120
              base_width_px: 40
      - type: conditional
        conditions:
            state: Living Room
        card:
          scale_icons: false
          entities:
              name: All in Room
              base_height_px: 120
              base_width_px: 40
      - type: conditional
        conditions:
            state: Play Room
        card:
          scale_icons: false
          entities:
              name: All in Room
              base_height_px: 120
              base_width_px: 40
      - type: conditional
        conditions:
        card:
          scale_icons: false
          entities:
              name: All in Room
              base_height_px: 120
              base_width_px: 40
      - type: conditional
        conditions:
        card:
          scale_icons: false
          entities:
              name: All in Room
              base_height_px: 120
              base_width_px: 40
      - type: conditional
        conditions:
        card:
          scale_icons: false
          entities:
              name: All in Room
              base_height_px: 120
              base_width_px: 40
  - type: conditional
    conditions:
        state: Kitchen
    view_layout:
      grid-column: 1 / -1
      grid-row: 2
    card:
      cards:
        - type: custom:enhanced-shutter-card
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
            style: |
              :host {
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
            style: |
              :host {
  - type: conditional
    conditions:
        state: Living Room
    view_layout:
      grid-column: 1 / -1
      grid-row: 2
    card:
      cards:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
            style: |
              :host {
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
            style: |
              :host {
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
            style: |
              :host {
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
            style: |
              :host {
  - type: conditional
    conditions:
        state: Play Room
    view_layout:
      grid-column: 1 / -1
      grid-row: 2
    card:
      cards:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
            style: ":host {\n  max-width: 190px !important;\n}\t\t\t  \n"
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
  - type: conditional
    conditions:
    view_layout:
      grid-column: 1 / -1
      grid-row: 2
    card:
      cards:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
  - type: conditional
    conditions:
    view_layout:
      grid-column: 1 / -1
      grid-row: 2
    card:
      cards:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
          card_mod:
  - type: conditional
    conditions:
    view_layout:
      grid-column: 1 / -1
      grid-row: 2
    card:
      cards:
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
              battery_entity: sensor.somfy_shade_battery_level_master_bathroom_1
              signal_entity: sensor.somfy_shade_rssi_master_bathroom_1
          card_mod:
            style: |
              :host {
          scale_icons: false
          entities:
              base_height_px: 120
              base_width_px: 40
              battery_entity: sensor.somfy_shade_battery_level_master_bathroom_2
              signal_entity: sensor.somfy_shade_rssi_master_bathroom_2
          card_mod:
            style: |
              :host {
