Aeon Multisensor 6 - no temperature
I have problems with my Aeon Multisensor 6. I have all the readings properly notified, but there is no temperature readings (there is no icon for it in HA).
Do you know what can be the reason of it?
Previously I was using this sensor with Domoticz and everything was OK. I didn’t modify anything from that time on the sensor or Z-Wave Dongle level.
I had a similar situation when moving my nodes from unsecured to secured connections. I ended up removing the node, doing a factory reset, adding it back, then waiting a couple of hours. It started working on it’s own after that.
i will try that, thank you
All my zwave sensors are unsecured. Not needed. Maybe the boiler actuator will be secured at one point.
Mutlisensor 6 works great here.
After your suggestion, everything started to work correctly.
