alkru002
(alkru002)
November 16, 2017, 5:45pm
1
Dear all,
it would be perfect if you can help me. I dont know why but I have always the problem that Home Assistant said that I have an invalid config.
I did many different things:
sudo apt-get install libudev-dev
result:
got a message that this is allready installed, so that should be ok.
and I did this steps:
The stick is active on this port:
ls -l /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 Nov 16 17:53 /dev/ttyUSB0
My config:
zwave:
usb_path: /dev/ttyUSB0
I have only this libs in the libary:
It would be perfect if you can help me.
Thank you
Operating System = Ubuntu
Home Assistant 0.57.3
installed like this: https://home-assistant.io/docs/installation/virtualenv/
Best regards
alkru002
Tinkerer
(aka DubhAd on GitHub)
November 16, 2017, 6:59pm
2
Did your config look like:
zwave:
That should be a valid config, if your USB stick is /dev/ttyUSB0
, and the user you’re running Home Assistant as is a member of the dialout
group.
zarthan
November 16, 2017, 11:28pm
3
@alkru002 The Aeon Zwave stick normally shows up as /dev/ttyACM0 on Ubuntu.
alkru002
(alkru002)
November 17, 2017, 9:08am
4
Hey,
thanks for your help.
I can check one more time the usb_path. It could be that I use the wrong command for the check. I am working so I cannot check which command I used to verify that was /dev/ttyUSB0.
But one more thing:
Is the libary pyhton_openzwave the right one?
Thanks.
BR alkru002
Tinkerer
November 17, 2017, 9:14am
5
Don’t worry about the libraries, Home Assistant automatically installs the required Python packages when you enable the Z-Wave component.
alkru002
(alkru002)
November 17, 2017, 6:52pm
6
Do you have any idea how I can find out which /dev/XXXX it is? It could be that it is the wrong one…
alkru002
(alkru002)
November 17, 2017, 7:14pm
8
Mh, damn I did this installation:
~$ ls -ltr /dev/tty*|tail -n 1
crw-rw---- 1 root dialout 188, 0 Nov 17 20:04 /dev/ttyUSB0
and my configuration is:
#zwave
zwave:
usb_path:/dev/ttyUSB0
Normally it must working. And the stick is active (blue light).
Tinkerer
November 17, 2017, 8:41pm
9
Does the time match when you connected the stick?
If not, you’ve got something else that you’re connecting. What does ls -ltr /dev/tty*|tail
show?
alkru002
(alkru002)
November 20, 2017, 5:38pm
11
Dear all I tested some things but I got this error:
File "/home/akruse/homeassistant/lib/python3.6/site-packages/homeassistant/components/zwave/__init__.py", line 269, in setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File "/home/akruse/homeassistant/lib/python3.6/site-packages/openzwave/option.py", line 81, in __init__
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyUSB0 : [\'Traceback (most recent call last):\\n\', \' File "/home/akruse/homeassistant/lib/python3.6/site-packages/openzwave/option.py", line 75, in __init__\\n raise ZWaveException(u"Can\\\'t write to device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \'openzwave.object.ZWaveException: "Zwave Generic Exception : Can\\\'t write to device /dev/ttyUSB0 : [\\\'NoneType: None\\\\\\\\n\\\']"\\n\']'
Any ideas? I dont have any idea…
I tested also different USB Ports with different /dev/tty*/
alkru002
(alkru002)
November 20, 2017, 5:43pm
12
I got it with this:
sudo chgrp akruse /dev/ttyUSB0
… they z wave config ist not invalid and I see
Tinkerer
November 20, 2017, 6:30pm
13
What user are you running Home Assistant as?
Is that user a member of the dialout
group?
alkru002
(alkru002)
November 20, 2017, 6:40pm
14
I run it with my user. I tried to install with an other user but it did not work.
Tinkerer
November 20, 2017, 8:44pm
15
If you type id
what do you get?
What does ls -l /dev/ttyUSB0
show?
alkru002
(alkru002)
November 21, 2017, 5:53pm
16
hi,
i get this:
uid=1000(akruse) gid=1000(akruse) groups=1000(akruse),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),118(lpadmin),128(sambashare)
crw-rw---- 1 root dialout 188, 0 Nov 21 18:29 /dev/ttyUSB0
Tinkerer
November 21, 2017, 6:44pm
17
Try
sudo usermod -G dialout akruse
Then reboot
