Hello all!
Just got this little thingy in the mail and adding it to the network (aeotec z-stick gen5 usb stick) went very smoothly. Everything seems to work except for the door status (always reports closed) even though i can see the updates coming in in the logs:
2025-03-25T23:23:52.800Z DRIVER « [Node 009] [REQ] [ApplicationCommand]
└─[Security2CCMessageEncapsulation]
│ sequence number: 150
│ extensions:
│ · type: SPAN sender EI: 0x
│ security class: S2_Authenticated
└─[SupervisionCCGet]
│ session id: 7
│ request updates: false
└─[NotificationCCReport]
notification type: Access Control
notification status: 255
notification state: Window/door is closed
2025-03-25T23:23:52.809Z DRIVER one or more queues busy
2025-03-25T23:23:52.820Z DRIVER » [Node 009] [REQ] [SendData]
│ transmit options: 0x24
│ callback id: 0
│ sequence number: 51
└─[SupervisionCCReport]
session id: 7
more updates follow: false
status: Success
duration: 0s
2025-03-25T23:23:52.828Z DRIVER « [RES] [SendData]
was sent: true
2025-03-25T23:23:52.832Z DRIVER all queues idle
2025-03-25T23:23:54.631Z DRIVER « [Node 009] [REQ] [ApplicationCommand]
└─[Security2CCMessageEncapsulation] [INVALID]
error: Security2CC_CannotDecode
2025-03-25T23:23:54.632Z CNTRLR » [Node 009] Message authentication failed, cannot decode command. Requesting a
nonce...
2025-03-25T23:23:54.637Z DRIVER one or more queues busy
2025-03-25T23:23:54.642Z DRIVER » [Node 009] [REQ] [SendData]
│ transmit options: 0x05
│ callback id: 204
└─[Security2CCNonceReport]
sequence number: 52
SOS: true
MOS: false
receiver entropy: 0x
2025-03-25T23:23:54.651Z DRIVER « [RES] [SendData]
was sent: true
2025-03-25T23:23:54.913Z DRIVER « [REQ] [SendData]
callback id: 204
transmit status: OK
2025-03-25T23:23:54.917Z DRIVER all queues idle
2025-03-25T23:23:55.036Z DRIVER « [Node 009] [REQ] [ApplicationCommand]
│ sequence number: 152
│ extensions:
│ session id: 10
notification state: Window/door is open
state parameters: Window/door is open in regular position
Any thoughts on this?
(HA runs on an older intel NUC: NUC6CAYH)
/EDIT
Interesting quirk, never had to reboot the whole system(i always do this even though it takes more time thn a simple reload) to get a zwave thingy working…
