I’ve just bought a Aeotec Key Fob Gen5 ZW088 and following installation instruction and I’ve quickly added it into my z-wave network (I can see device and two entities).
Starting from that stage I’m unable to do anything else… I’ve changed the mode (from setup mode to use mode) on device and pressing the 4 buttons nothing happens and no z-wave log seen coming from that device id.
Did anyone have some experience to share?
I would like to use it to open garage door and external access using some HA automation.
did you have any luck in setting up this device? I just bought two of these and I see one device and two entities (AEON Labs ZW088 Key Fob Gen5 + battery level). I’m new to zwave. thanks.
just a note…if you are trying to use this on a Pi 4…check the back of the Aeon stick…does it say NEW on the label. If not, you have an older version (same model number) and you need to run it through a USB 2 (NOT 3) hub…it can be a very cheap one.
