I have 4 Aeotec Multisensor 6’s which work great. One of them started to report water level which is not one of its capabilities. I have disabled that entity so it’s not reporting. The question is why did this start showing up and is there a way to get rid of it from the device config? I’ve reinterviewed and healed the device and it’s still showing up.
Do you know which firmware they are using? I have a bunch of these, all running v1.15 and have not seen the issue you’re reporting. You can try deleting the water level entity, or you could exclude / factory reset / include the whole thing. I’d go for the latter, and consider a firmware update if possible.
