I am using Aeotec Z-Stic gen5. I added a multi-functional sensor 6. Everything is ok except the motion sensor, which in the long run indicates 3 and sometimes changes to 8 regardless of whether it has detected motion. I set parameter 4 to 5.
Can you help me set the motion sensor to work properly?
In general, the multisensor 6 sends a notification of “Tampering”, “Motion” or “Clear” using a single value parameter. Looking at a version 1.6 OpenZwave notification xml, 3 means Tampering, 8 means Motion, and 0 means Clear. If you are not shaking/vibrating the multisensor 6, then you should only get Motion reports followed by Clear.
I didn’t have to do any particular settings with my Multisensor6; param4 for me is set at the default level of 5…
You should also have a binary_sensor entity for the sensor. When that binary sensor is on, motion was detected. When that binary sensor is off, everything’s clear.
