Aeotec Smart Plug 7 power report slow
Does anyone here use Aeotec smart plug 7’s?
I installed one today. The plug connected nicely using S2. It responds quickly and I really like the options it has compared to the Fibaro power plugs.
However, there is one thing I can’t seem to figure out. The power report is horrible slow. When I turn of the plug the power value does nog change in ZwaveJS. Even after 20 minutes the power usage is still 0.
When I go into ZwaveJS UI and I refresh the values for the power meter, it updates.
I would like the plug to report the power usage instantly, like the Fibaro power plug does. I already set the power report threshold to 1W but this does make a difference.
Is there any solution for this? Really like the plug compared to the Fibaro because of the extra features. But without a proper power measure, the plug is not really well suited for automations that rely on the power usage.
Hopefully some has a fix. :slightly_smiling_face:
Updated the firmware of the plug. Reset the power plug to factory setting and repaired it. Now it’s reporting it correctly. with the treshold set to 1W.
