Hi all,
I’ve purchased a Wallmote quad, and looking through the other threads seemed fairly straight forward to setup in HA, however, does not seem to be the case.
I’ve added it to the network, and it showed as complete, and as per the instruction here I updated the config after shutting down HA.
Now in the config, the device is stuck as Initilizing, see the image
And this in the log:
2020-10-25 13:16:32.842 Detail, Node003, Queuing (WakeUp) SwitchBinaryCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x25, 0x01, 0xff, 0x25, 0x0c, 0x14
2020-10-25 13:16:32.842 Info, Node003, SwitchBinaryCmd_Get Not Supported on this node
2020-10-25 13:17:17.005 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=ProtocolInfo live=1
2020-10-25 13:17:17.005 Detail, Node003, QueryStage_Probe
2020-10-25 13:17:17.005 Info, Node003, NoOperation::Set - Routing=true
2020-10-25 13:17:17.005 Detail, Node003, Queuing (WakeUp) NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x0d, 0xcc
2020-10-25 13:17:17.005 Detail, Node003, Queuing (WakeUp) Query Stage Complete (Probe)
Not sure what to do here, I’ve tried starting and stopping the Z-Wave network, restarting HA and nothing.
I seem unable to set any of the configuration values, but button presses do appear to register:
2020-10-25 13:23:07.818 Info, Node003, Received Central Scene set from node 3: scene id=1 in 0 seconds. Sending event notification.
2020-10-25 13:23:07.818 Detail, Node003, Refreshed Value: old value=0, new value=0, type=int
2020-10-25 13:23:07.818 Detail, Node003, Changes to this value are not verified
2020-10-25 13:23:07.818 Detail, Node003, Notification: ValueChanged
Any ideas what to do next?
