After 0.78 a lot of errors in log?
After installing 0.78 (latest release) I get a lot of errors in log and sensor.DHT error in frontpage… Something went wrong?
Are you able to provide more details? Unfortunately most of us can’t read minds so we can’t really help with that info :wink:
:rofl:
I’ll be back home in noon, I’ll post my log
This is my home-assistant.log. If I check config all is ok…
2018-09-19 08:12:07 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2018-09-19 08:12:21 ERROR (MainThread) [homeassistant.components.media_player.squeezebox] Could not communicate with 192.168.1.200:9002:9000: [Errno -2] Name does not resolve
2018-09-19 08:13:48 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package Adafruit-DHT==1.3.4: Failed building wheel for Adafruit-DHT
wirelesstagpy 0.3.0 has requirement colorlog==3.0.1, but you'll have colorlog 3.1.4 which is incompatible.
waterfurnace 0.7.0 has requirement websocket-client>=0.47, but you'll have websocket-client 0.37.0 which is incompatible.
upsmychoice 1.0.6 has requirement beautifulsoup4==4.5.1, but you'll have beautifulsoup4 4.6.3 which is incompatible.
upsmychoice 1.0.6 has requirement python-dateutil==2.6.0, but you'll have python-dateutil 2.7.3 which is incompatible.
upsmychoice 1.0.6 has requirement requests==2.12.4, but you'll have requests 2.19.1 which is incompatible.
toonlib 1.0.2 has requirement cachetools==2.0.0, but you'll have cachetools 2.0.1 which is incompatible.
toonlib 1.0.2 has requirement requests==2.13.0, but you'll have requests 2.19.1 which is incompatible.
temperusb 1.5.3 has requirement pyusb>=1.0.0rc1, but you'll have pyusb 1.0.0b1 which is incompatible.
spotcrime 1.0.3 has requirement requests==2.12.4, but you'll have requests 2.19.1 which is incompatible.
skybellpy 0.1.2 has requirement colorlog==3.0.1, but you'll have colorlog 3.1.4 which is incompatible.
python-velbus 2.0.19 has requirement pyserial==3.3, but you'll have pyserial 3.1.1 which is incompatible.
python-jose-cryptodome 1.3.2 has requirement pycryptodome<3.4.0,>=3.3.1, but you'll have pycryptodome 3.6.6 which is incompatible.
pysma 0.2.0 has requirement aiohttp<3,>2, but you'll have aiohttp 3.4.4 which is incompatible.
pysma 0.2.0 has requirement async-timeout<3,>2, but you'll have async-timeout 3.0.0 which is incompatible.
pymysensors 0.17.0 has requirement pyserial>=3.4, but you'll have pyserial 3.1.1 which is incompatible.
pymonoprice 0.3 has requirement pyserial>=3.4, but you'll have pyserial 3.1.1 which is incompatible.
pymata 2.14 has requirement pyserial==2.7, but you'll have pyserial 3.1.1 which is incompatible.
pyicloud 0.9.1 has requirement keyring<9.0,>=8.0, but you'll have keyring 15.0.0 which is incompatible.
pyicloud 0.9.1 has requirement keyrings.alt<2.0,>=1.0, but you'll have keyrings-alt 3.1 which is incompatible.
pyblackbird 0.5 has requirement pyserial>=3.4, but you'll have pyserial 3.1.1 which is incompatible.
nad-receiver 0.0.9 has requirement pyserial==3.2.1, but you'll have pyserial 3.1.1 which is incompatible.
myusps 1.3.2 has requirement beautifulsoup4==4.6.0, but you'll have beautifulsoup4 4.6.3 which is incompatible.
myusps 1.3.2 has requirement python-dateutil==2.6.0, but you'll have python-dateutil 2.7.3 which is incompatible.
myusps 1.3.2 has requirement requests==2.12.4, but you'll have requests 2.19.1 which is incompatible.
myusps 1.3.2 has requirement selenium==2.53.6, but you'll have selenium 3.14.0 which is incompatible.
mycroftapi 2.0 has requirement websocket-client==0.44.0, but you'll have websocket-client 0.37.0 which is incompatible.
motorparts 1.0.2 has requirement beautifulsoup4==4.5.1, but you'll have beautifulsoup4 4.6.3 which is incompatible.
motorparts 1.0.2 has requirement requests==2.12.4, but you'll have requests 2.19.1 which is incompatible.
magicseaweed 1.0.0 has requirement requests==2.12.4, but you'll have requests 2.19.1 which is incompatible.
locationsharinglib 2.0.11 has requirement beautifulsoup4==4.6.0, but you'll have beautifulsoup4 4.6.3 which is incompatible.
libsoundtouch 0.7.2 has requirement websocket-client>=0.40.0, but you'll have websocket-client 0.37.0 which is incompatible.
insteonplm 0.14.2 has requirement pyserial==3.2.0, but you'll have pyserial 3.1.1 which is incompatible.
hipnotify 1.0.8 has requirement requests==2.9.1, but you'll have requests 2.19.1 which is incompatible.
gearbest-parser 1.0.7 has requirement beautifulsoup4==4.6.0, but you'll have beautifulsoup4 4.6.3 which is incompatible.
fedexdeliverymanager 1.0.6 has requirement beautifulsoup4==4.5.1, but you'll have beautifulsoup4 4.6.3 which is incompatible.
fedexdeliverymanager 1.0.6 has requirement python-dateutil==2.6.0, but you'll have python-dateutil 2.7.3 which is incompatible.
discord-py 0.16.12 has requirement aiohttp<1.1.0,>=1.0.0, but you'll have aiohttp 3.4.4 which is incompatible.
discord-py 0.16.12 has requirement websockets<4.0,>=3.1, but you'll have websockets 6.0 which is incompatible.
crimereports 1.0.0 has requirement requests==2.12.4, but you'll have requests 2.19.1 which is incompatible.
broadlink 0.9 has requirement pycryptodome==3.4.11, but you'll have pycryptodome 3.6.6 which is incompatible.
alarmdecoder 1.13.2 has requirement pyserial==2.7, but you'll have pyserial 3.1.1 which is incompatible.
abodepy 0.13.1 has requirement colorlog==3.0.1, but you'll have colorlog 3.1.4 which is incompatible.
Command "/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-e7ldupt1/Adafruit-DHT/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-3dgft2ip/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-e7ldupt1/Adafruit-DHT/
You are using pip version 10.0.1, however version 18.0 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
2018-09-19 08:13:48 ERROR (MainThread) [homeassistant.requirements] Not initializing sensor.dht because could not install requirement Adafruit-DHT==1.3.4
2018-09-19 08:13:48 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.dht: Could not install all requirements.
2018-09-19 08:13:50 WARNING (SyncWorker_12) [homeassistant.components.sensor.darksky] Monitored condition temperature_min is deprecated
2018-09-19 08:13:50 WARNING (SyncWorker_12) [homeassistant.components.sensor.darksky] Monitored condition temperature_max is deprecated
2018-09-19 08:13:56 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-19 08:14:03 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-19 08:14:09 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-19 08:15:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 08:20:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 08:25:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 08:30:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 08:35:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 08:40:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 08:45:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 08:45:15 ERROR (MainThread) [frontend.js.latest.201809160] :0:0 Script error.
2018-09-19 08:50:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 08:55:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:00:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:05:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:09:38 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
2018-09-19 09:09:38 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
2018-09-19 09:09:39 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-09-19 09:09:39 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-09-19 09:10:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:12:23 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None
2018-09-19 09:15:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:20:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:25:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:30:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:35:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:40:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:45:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:50:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 09:55:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:00:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:05:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:10:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:15:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:20:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:25:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:30:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:35:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:40:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:45:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:50:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 10:55:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:00:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:05:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:10:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:15:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:20:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:25:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:30:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:35:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:40:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:45:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:50:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 11:55:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:00:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:05:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:10:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:15:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:20:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:25:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:30:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:35:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:40:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:45:00 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: 'None' has no attribute 'state'
2018-09-19 12:47:19 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-09-19 12:47:19 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
what’s your setup? if indeed hass.io something went wrong during the update. I don’t use hass.io do not too sure how to force an upgrade or reapply an upgrade.
You appear to have some sort of automation that runs every 5 min giving you the Error during template condition: UndefinedError: 'None' has no attribute 'state'
Check your conditions, one is likely to be trying to check a sensor’s state but that sensor has not received its data yet and therefore not initialised. There are a few ways to stop this error from showing up. If you share your condition I’ll show you how.
The sensor is a DHT22 attached to Raspi. It worked until update, now sensor.DHT stopped working and I get "Unable to install package Adafruit-DHT==1.3.4: Failed to building wheel for Adafruit-DHT".
Is it possible to force a reinstall of the update (in Hass.io)?
just checked and it looks like an issue has already been reported:
So it’s all sensor.DHT related???
would appear so
:roll_eyes: hope they’ll solve ASAP!!!
