I configured Occusim to start when my alarm system is in AWAY mode and time is over 17:00 and until 23:59
But after upgrade to v. 0.83 it is always active.
Before upgrade it worked fine for a month with this configuration
Ok, I checked it and discovered I had both ha_key and token …
then I removed ha_key from appdaemon.yaml
No I have this warning…
2018-12-02 13:35:14 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.5
2018-12-02 13:35:19 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.5
2018-12-02 13:35:24 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.5
2018-12-02 13:35:29 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.5
2018-12-02 13:35:34 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.5
2018-12-02 13:35:39 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.30.33.5
2018-12-02 13:35:39 WARNING (MainThread) [homeassistant.components.http.ban] Banned IP 172.30.33.5 for too many login attempts
@ReneTode
im having a similar issue. running hassio on virtualbox.
Installed appdaemon, all seemed ok. however i get the Login attempt or request with invalid authentication from x.x.x.x which is my tablet with the dash running.
If i remove the token from the appdaemon yaml it automatically puts one back in. When this hppens hassio also issues new tokens for my axis cameras (which are on the dash main page), so i also lose camera feeds. yet the buttons etc i have on the dash all work ok.
been scratching my head for a couple of days on and off.
freck created the addon, i dont have it installed and no knowledge about it.
i am there for every other appdaemon and dashboard question.
and its in most of the times hard to know if a problem is caused by the addon or AD, for other people.
i can tell because i have seen all the questions
