After installation Homeassitant not found
After installation Homeassistant cannot be found by browser, ping the ipadress does work. Via Fritzbox homeassistant is visible but cannot be started \192.168.178.53 failed but editing to \192.168.178.53:8123 does work. In the browser this address cannot be found. It looks like Fritzbox is the problem.
Any suggestions?
Homeassistant is listening on port 8123 and you can access it by going to http://IP:8123
Hi Fred, welcome to the forum!
What do you mean exactly by ‘cannot be started’, what are you editing and why are you putting 1 backslash in front of that IP address?
As Daniel mentions: browse to http://IP:8123
If that doesn’t work, make sure you have the right IP and you could simply ping with the -t option and disconnect the network cable to make sure you are looking at the right thing.
Also, some browsers switch to httpS, so make sure to use the right protocol.
What system are you running HA on and which type of installation did you use?
