After last versione update problem with a new automation
Good morning, after the latest update, I noticed that it’s no longer possible to create a new automation and immediately edit it in YAML; instead, a pop-up appears stating that you can only edit automations already present in the automation.yaml file. Furthermore, I solved this problem by duplicating an existing automation, renaming it, and saving it, then switching to YAML edit mode and saving it again. However, there’s still an issue here: the automation doesn’t appear in the list of automations; it only shows up after restarting Home Assistant! Am I the only one experiencing this problem? Thanks.
There are buttons to reload automations only. One place is type ‘c’ while on the dashboard and in the popup start typing automations, you will see an automation reload.
